Before you start
Who can use this feature
Starter, Professional, Education, Organization, and Enterprise plans
Requires a supported MCP client connected to the remote Figma MCP server
With the Figma MCP server, you can capture live UI from your browser and turn it into editable Figma design layers. Capture a single screen or an entire flow in one session.
UI built in code often grows organically, and sharing it usually means sending screenshots or asking someone to run a build. Capturing it to Figma instead lets you see every step of a multi-step flow side by side, so issues like abrupt permission prompts, unclear empty states, or steps that should be combined are easier to spot.
Captured frames are standard Figma layers. Your team can organize, duplicate, rearrange, edit copy, and annotate decisions on the canvas. When you're done, share a link to the updated frame with your agent so it can implement the changes in code. This completes the round trip: code to canvas for review, then back to code.
Note: Code to canvas is different from writing to the canvas. Code to canvas captures your running UI as flat layers, without a connection to your libraries. Writing to the canvas lets your agent build with your existing components and variables. You can use them together: capture your latest UI, then have your agent refine it with your design system.
Code to canvas is one of several ways to bring coded screens into Figma. For other methods, like the Figma Chrome extension, see Turn coded screens into editable design layers.
Note: To turn HTML from your codebase, or HTML your agent creates, into design layers without running your app, your agent can use html_to_figma instead. To bring a page into Figma as a code layer you can keep building in Figma Make, use the Figma Chrome extension.
Supported clients
Code to canvas works with these MCP clients:
- Augment
- Claude Code
- Codex by OpenAI
- Cursor
- Factory
- Firebender
- VS Code
- Warp
- Xcode
Capture your UI
Your agent uses the generate_figma_design tool to capture UI to one of these destinations:
- A new Figma Design file, created in your drafts
- An existing Figma Design file. Requires edit access to the file.
- Your clipboard, so you can paste the layers into any file
- Set up the remote Figma MCP server for your client.
Prompt your agent to capture your UI. For example:
- To a new file: "Start a local server for my app and capture the UI in a new Figma file."
- To an existing file: "Start a local server for my app and capture the UI in <Figma file URL>." If the link isn't to a Figma Design file, your agent creates a new file instead.
- To your clipboard: "Start a local server for my app and use the Figma MCP server to capture the UI to my clipboard."
Your agent starts the server, adds the script that code to canvas needs, and opens a browser window. It may ask which Figma team or organization to use. The first capture happens automatically when the window opens.
- Use the toolbar in the browser window to capture more of your UI, including different states:
- Click Entire screen to capture the full current view.
- Click Select element to capture a specific element.
When you're done:
- If you captured to a Figma Design file, click Open file.
- If you captured to your clipboard, paste the layers into a Figma file.
You can also ask your agent to finish the capture for you.
Note: If the file you capture to has a library with variables, Figma automatically binds matching color, number, and string variables to the captured layers. To use your own variables, add the library to the file before you capture. Learn more about how variables are matched.
Tips
- Skip the server step if it's already running. If a local server is already running, you can leave out "Start a local server for my app" from your prompt. Your agent can often work out that it needs a server, but it helps to say so the first time.
- Keep capturing to the same file. In the same conversation, your agent usually assumes you want to keep using the same file, or asks to confirm. For example, after "Capture the login page to <Figma file URL>," you can say "Capture checkout to the same file" or just "Also capture the account screen."
- Pick from recent files. When you capture to an existing file, your agent can suggest files you've recently created or edited.
- Capture a live site. To capture a live web app or site instead of a local one, ask your agent to use a tool like Playwright to add the required script.
For more tips on getting accurate captures, see Tips for better captures.
Troubleshooting
The generate_figma_design or use_figma tool isn't available
These tools are only available on the remote server, not the desktop server. If your client doesn't list them:
Check that the remote server is set up. Look in your client's MCP configuration for
https://mcp.figma.com/mcp. If it's missing, set up the remote server. -
Check whether the desktop server is also set up. This is the most common cause. If you set up the desktop server before, it's still in your client's configuration. The Figma desktop app runs it at
http://127.0.0.1:3845/mcpwhenever the app is open. Because both servers have similar tool names, your client may use the desktop server and never load the remote-only tools.In Claude Code, list your servers:
claude mcp list
If there's an entry for
http://127.0.0.1:3845/mcpnext to your remote server, remove it:claude mcp remove figma-desktop
In other clients, open your MCP configuration file and remove or comment out any server with the URL
http://127.0.0.1:3845/mcp. - Restart your client. Clients load their tool list when they start. Restart after changing the configuration, then check that the tools are available.
Note: You can also turn off the desktop server in the Figma desktop app: switch to Dev Mode and turn off the server in the MCP server section of the right sidebar. It turns back on the next time the app opens with the server enabled, so removing it from your client's configuration is the more lasting fix.
If you use both servers on purpose, give them different names, such as figma for the remote server and figma-desktop for the desktop server, and name the remote server in your prompts.
