This article covers how to create a new widget in FigJam, and is only one step in the widget development process.
The widget development process:
- Setup your development environment →
- Create a widget for development →
- Publish widgets to the Figma Community →
- Manage widgets as a developer (Current article)
Check out our Widget Developer docs for a complete guide on making widgets for FigJam.
Update a widget
Publish a new release
Publishing a new widget release requires the Figma desktop app for macOS or Windows. Download the Figma desktop app →
Only the original widget publisher can publish updates to a widget. You can still list other contributors to the widget as creators, but they won't be able to publish any changes.
Once Figma approves your widget, you no longer need to submit your widget for further review. This means you can publish any updates immediately.
When you publish an update, Figma will update the widget for every user. Users who have already installed your widget will only have access to the latest version of your widget.
It's not possible for users to revert to a previous version of the widget. If you need to roll back any changes, you can republish an earlier version of the widget.
The process for submitting an update is the same as the original publishing process. You can update any information about your widget, including the name, description, tags, creators, and any artwork.
- Open a file on the Figma desktop app.
- Click the Figma logo in the upper-left corner, then go to Widgets > Manage widgets.
- Click next to the widget you'd like to update and select Publish new version.
Note: If you don't see Publish new version in the list of options, select Locate local version. In the file selector, go to the directory that contains the version of your widget that you want to publish. Then, select the manifest.json file for your widget and click Okay. You should now see Publish new version in the list of options.
- Use the Publish widget modal to update widget information as needed.
- (Optional) Update the security self-assessment form on the Data security page. If you've previously submitted the self-assessment and the form has not yet been approved, a banner appears in the form to identify that the widget is still under review.
- (Optional) On the Add final details page, enter details about the changes to your widget in the Release notes box.
- Update any other fields as needed.
- Click Publish to complete the process. Figma will update the widget for everyone that has it installed.
Edit a Community page
Your widget's Community page helps users understand what your widget does and allows them to install it for use. Creators, contributors, and publishers of a widget can edit the details of the widget's page at any time without having to publish an update.
- Open the widget's Community page.
- In the upper-right corner of the page, click Manage resource > Edit this page.
- In the Publish widget modal, update the desired fields, then click Publish when you're finished.
Manage permissions
Invite additional publishers
Once your widget is published to the Figma Community, you can invite others to help publish updates to your widget. Learn how to invite additional publishers →
Transfer ownership of private organization widgets
Owners of private organization widgets transfer ownership to any one who has permission to publish a resource. Organization admins can also transfer ownership of private widgets to another organization member.
Note: You cannot transfer ownership of widgets published outside of an organization.
- Open a Figma Design or FigJam file on the Figma desktop app.
- Open the permissions modal:
- Click and select the Widgets tab.
- Open the dropdown menu and select Development.
- Click next to your widget and select Manage permissions.
- Click the dropdown next to a publisher’s name.
- Select Owner. The former owner will have their permissions changed to Can update.
Remove a widget
If you're a developer of a widget, you can remove a widget at any stage of the development process.
Published
If your widget is published to the Figma Community, unpublishing your widget will remove it for anyone who has installed it. Users who've installed your widget won't receive a notification if it's been unpublished.
Note: Paid widgets cannot be unpublished but can be delisted. Learn more about delisted paid resources →
We recommend warning your users of your plans to unpublish the widget. For example, you can add a note to the widget description or your personal website with the date you will unpublish the widget.
Unpublish from a Community page
- In the upper-right corner of the page, click Manage resource > Unpublish.
- In the Unpublish widget modal, click Unpublish.
Unpublish while in a file
- Click next to the widget you want to unpublish and select Unpublish from the options.
The widget will be removed from the Figma Community and users will no longer be able to use the widget or view the listing. The widget will remain in development on your account.
When removing a widget from the Community, likes and installs will be retained, but any details—such as title, tagline, description, and so on—will be lost.
In development
If you decide to cease development of a widget, or want to start from scratch, you can remove the widget. This will delete the widget from Figma, but you can still access the manifest from your computer.
- Click next to the widget you want to remove and select Remove from the options.
It's not possible to restore a deleted widget. Deleting a widget will also remove any likes and installs you have acquired, even if you publish the same widget in the future.
Provide support
Figma does not provide support for third-party applications. As the widget's developer, it's your responsibility to assist your widget users with technical issues.
You need to add a Support contact when you submit your widget for approval. This can be an email address users can contact or a link to a website or help center.
