- FigJam is Figma's new digital whiteboarding tool.
- Anyone with can edit access in a FigJam file can use libraries.
With libraries in FigJam, you can add to your board stickers and components created by your team and members of the Figma Community.
- Stickers are default objects curated by Figma you can add to your FigJam board. Use them to add flair and reactions to your board.
- Components are reusable design elements created in Figma Design, by you or your team. Learn more about components →
You can only create components in Figma Design. Once created, they can be accessed and used in both FigJam and Figma Design files.
Use libraries
Access your team's components and stickers curated by Figma with the library.
Browse libraries
To browse your libraries:
- Click in the toolbar. Or use the keyboard shortcut ⌥ Option2 / Alt2 to open the modal.
- Select the Stickers tab.
- Search for stickers and components or browse your libraries.
- Click and drag an object from the library to your board.
Right-click a sticker from the Recents section of the library and select View stickers in this set to navigate to the library it was chosen from.
Select variants
If your component has variants, you can select variants from the inline menu.
- Add the component to the board.
- If it has variants, the menu will show when it's selected.
- Click to open the menu and select a variant:
Manage libraries
In addition to Figma's built-in stickers, you can also add regular component libraries to your FigJam files. You can choose which libraries are available in each file.
Add library
To make a library available in all FigJam files, team admins can toggle libraries for all team Figma Design or FigJam files. Enable libraries in team files →
- Under Libraries, click Add your own to add a library.
- From Manage libraries, you can view any libraries you have access to. Use the search field to find a specific library or browse the list of available libraries.
- Click Add to file to make that library available in the current file.
Update library
Accept updates from published libraries to see the updated instances on your board.
To update libraries in FigJam:
- You'll see a banner notifying you of any updates to your components.
- Click Update to accept the changes in FigJam.
Remove library
If you don't want a library to show up in the file anymore, you can remove it. This will only remove the library from this file and won't remove any components you've added to the board.
- You'll see any libraries you've added at the top of the modal. Hover over the Added button for the library you want to remove.
- Click Remove to remove the library for this file only.
It's not currently possible to remove Figma's default stickers from your libraries, or change the order they appear.
