Create text and links in FigJam
- Anyone with can edit access can create and edit text in FigJam files.
- FigJam is Figma's new digital whiteboarding tool.
Text is a crucial element for jotting down ideas while brainstorming and communicating information to others.
Links can be used to cross-reference other FigJam or Figma files, direct collaborators to product documentation, or link to external websites.
In this article, we'll take you through how to create and modify text and link objects in FigJam.
Create a text object
Click in the toolbar or press T to add text to the board.
Text objects are used to add text on top of other objects or directly to the board.
Single click
Single click creates a text box that resizes horizontally as you type, also known as point text. Drag the sides of a text box to adjust its width.
- Select the text tool or press T .
- Click anywhere on the board to create a text box.
Click and drag
Use click and drag to create a text box that wraps any horizontal overflow text to the next line. This is also known as area text. The object has a fixed width and grows vertically as you add more text.
- Click and hold anywhere the board.
- Drag your cursor to create a text layer with specific dimensions.
Double-click the bounding box of an area text to convert it to point text.
Text properties
Many objects in FigJam contain text, including text objects, shapes, sticky notes, and connectors. When you select text or enter text edit mode, a toolbar appears with options to change its properties.
Each kind of object has a specific number properties you can modify.
Bold
Apply the bold property to any text you want to stand out.
Click in the text toolbar, or use the keyboard shortcut:
- Mac: ⌘ Command B
- Windows: Control B
Strikethrough
Apply the strikethrough property on any text you want to cross out. This is great for crossing off tasks in a to-do list or ideas you decided to not pursue, but want to keep a record of.
Click in the toolbar, or use the keyboard shortcut:
- Mac: ⌘ Command ⇧ Shift X
- Windows: Control Shift X
Lists
Lists are great for note-taking, task lists, ideating, or writing step-by-step instructions while keeping your content clean and organized.
Bulleted list
Click in the toolbar, or use the keyboard shortcut.
- Mac: ⌘ Command ⇧ Shift 8
- Windows: Control Shift 8
You can also create a bulleted list on a new line by typing * Space or - Space.
Numbered List
Use the keyboard shortcut:
- Mac: ⌘ Command ⇧ Shift 7
- Windows: Control Shift 7
You can also create a numbered list on a new line by typing 1 . Space. If a numbered list already exists directly above your new line, try using the next number in the sequence instead.
Increase and decrease indent
To increase or decrease the indent of a list item, use these keyboard shortcuts:
- Increase indent: Tab
- Decrease indent: Shift tab
Text size
There are five size presets:
- Small (16px)
- Medium (24px)
- Large (40px)
- Extra large (64px)
- Huge (96px)
- Custom size
By default, text is set to Small for all text objects. You can change the size of all the text or a selected portion.
To use a preset text size:
- Select the line or portion of text you want to resize.
- Click the size dropdown menu in the toolbar to change text size.
- Pick a size for the selected text or enter a custom size in the field.
Text objects created with the tool can be given a custom size. To resize a text object:
- Select the text object you want to resize.
- Click and drag a corner of the text object.
Text objects can be resized in increments of 8 pixels, and will display as Teensy, Custom, or Ginormous in the size dropdown of the toolbar.
Curated colors
Change the color of your text to increase visibility, make it stand out, or group similar ideas. Choose from any of the eight curated colors in the color dropdown of the toolbar.
Learn more about colors in FigJam →
Alignment
- Select an object or a specific string of text.
- Click the alignment icon in the toolbar and choose:
- Text align left
- Mac: ⌥ Option ⌘ Command L
- Windows: Alt Control L
- Text align center
- Mac: ⌥ Option ⌘ Command T
- Windows: Alt Control T
- Text align right
- Mac: ⌥ Option ⌘ Command R
- Windows: Alt Control R
- Text align left
Add links to text
Add clickable links to text to reference Figma files, FigJam files, documentation, or external websites.
- Click , or use the keyboard shortcut:
- Mac: ⌘ Command K
- Windows: Control K
- Enter or paste the URL from your clipboard.
If you already have the URL copied to your clipboard, select the text and press ⌘ Command V / Control V to insert your link.
If you need a reminder of keyboard shortcuts, open your file's menu > Help and account > Keyboard Shortcuts. A tray will appear at the bottom of your window where you can explore different shortcuts.
