Connected folders launched in the first half of 2025. Connected folders let two separate teams or organizations—like an agency and a client—work together in a shared folder using billable seats from their own plans.
If you are a freelancer or agency working with clients in Figma—and you're not using connected folders—there are a few things to consider when setting up Figma so you can work together effectively. This guide helps you navigate the two primary approaches:
Invite clients to your team
For agencies who prefer to manage folders within their own Figma team, we recommend inviting clients to your team. There are a few things to consider with this approach:
- Choosing a plan type: If you have more than three design files and FigJam files on a Starter team, you’ll likely need a paid plan to collaborate with clients.
- Assigning clients a seat type: If client involvement is limited to leaving comments, we recommend assigning them a free View seat. This allows clients to comment on and review work without you needing to pay for their access. In scenarios where clients need to edit or contribute actively, they will need a paid seat on your team.
- Working in folders and files: You can invite clients to an entire folder, individual files, or both. We recommend not inviting them to your team or organization as this may grant them access to work you’ve created for other clients.
Transferring work after the engagement is complete: After work has completed, you have a few different options for transferring work:
- If your client uses Figma on the Organization or Enterprise plans, you can transfer a folder—or your entire Professional team—to their organization.
- If your client uses Figma on the Professional plan, you can save a copy of your files to your computer and your clients can import them to their account. If a file uses styles or components from a team library, it won’t receive any library updates after it is imported into a different account.
Request an invite to a client’s team or organization
For agencies who manage folders in clients’ Figma teams or organizations, there are several things to consider:
Requesting the right seat: You'll need a paid seat in your clients' team or organization before you can edit files.
- Requesting access to the right teams, folders, and files: Be sure to double check you’re invited to everything you need.
- Accessing work after the engagement is complete: After work has completed, your client may remove your access to their team or organization. Make sure to discuss in advance if you can save a local copy of your work.
- Keeping your personal work separate: If your agency's work is predominantly within client teams, consider maintaining a free Starter team for your personal work.
