Who can use this feature
Professional, Organization, Government, and Enterprise plans for both parties
Admins only
Requires approval from admins of both parties
Connected folders let two separate teams or organizations—like an agency and a client—work together in a shared folder using billable seats from their own plans. This makes it easy to design together, share resources, and hand off files smoothly—without paying for extra seats.
Note: Starting August 3, 2026, projects are being transitioned to folders, with the rollout reaching all users over the next few weeks. Your content and access will remain the same.
How connected folders work
A connected folder gets created in one plan and then shared with another.
- The party which creates the folder and sends a request to connect is the host.
- The party which receives the request to join the connected folder is the external team.
Note: There can only be one host and one external team per folder.
Who manages the connected folder
Admins from both parties can view the connected folder in their own Admin settings. Since the folder originates in the host’s team or organization, the host has more control over the settings and permissions of the folder.
| Host admins | External admins | |
| View the connected folder in Admin | ✓ | ✓ |
| View members of the connected folder | Can view all members of the folder | Can only view people from their own team |
| Manage security and privacy features for the folder | ✓ | X |
| Allow people from the external team to use the host’s libraries | ✓ | X |
| Manage AI feature availability | ✓ | X |
| Disconnect a folder | ✓ | ✓ |
| Manage the folder after it is disconnected, including sharing a copy or transferring it | ✓ | X |
Note: The host’s plan determines which features are available in the connected folder.
If the host is on the Enterprise plan, and the external team is on the Professional plan, all features of the Enterprise plan are available to everyone in the folder. This includes features like the number of variable modes, approved libraries, and security settings like requiring password protection on publicly shared files.
The reverse is also true. If the host is on the Professional plan and the external team is on the Enterprise plan, the connected folder is limited to the functionality of the Professional plan for both parties.
Note: Both parties can create, move, or import files into a connected folder. However, only people from the host team or organization can remove files from it.
Connected folders and nested folders
Connected folders have two requirements:
- Connected folders must be top-level folders. You can't nest a connected folder inside another folder.
- Connected folders can't contain subfolders. Files can live inside a connected folder, but you can't create a nested folder structure inside one.
These constraints prevent unintended access paths and make connected folders easier for admins to manage. Both parties can still add, move, and organize files within the connected folder.
Learn more about creating and managing folders.
How seats work in connected folders
In Figma, a person's seat determines which Figma products they have access to. For example, a user with a Collab seat has access to FigJam and Figma Slides.
Seats are separate from permissions—to determine which individual files a user can edit, you can give them can edit or can view permission on each file. To edit a file in a connected folder, a user needs both the relevant seat and can edit file permissions. Learn more about sharing and permissions.
People can work in a connected folder based on the seat they have in their own plan or organization. The host won’t be billed for users in the external plan, and vice versa. Any seat upgrade requests continue to be routed to the user’s own admins.
If a user from the external team is invited to edit files outside of the connected folder in the host plan or organization, they will need a seat on the host’s plan.
Note: If a user is invited to the folder and doesn’t currently have an account with either the host or the external team, they are added to the host’s plan with a View seat. If they require a paid seat, their upgrade request is routed to a host admin.
How AI credits and MCP rate limits work in connected folders
AI credits and MCP rate limits follow different rules for files in an active connected folder.
AI credits
Your AI credits come from the plan where you have the higher membership level. Members rank higher than guests.
- If you're a member of one plan and a guest on the other, your AI credits come from the plan where you're a member.
- If you're a member of both plans, or a guest on both plans, your AI credits come from the host plan.
Your seat on the selected plan determines your included AI-credit allowance.
For example, if you're a member of both plans and have a View seat on the host plan and a Full seat on the external plan, your included AI-credit allowance is based on your View seat on the host plan.
After your included seat credits run out, you may be able to use purchased credits from the same plan, depending on your eligibility, available credits, and any usage limits set by admins.
MCP rate limits
MCP rate limits depend on two things:
- Plan tier: Figma always uses the host plan’s tier, such as Professional or Enterprise.
- Seat type: If you’re a member of the external plan and a guest on the host plan, Figma uses your external seat—even if you have a seat on the host plan. Otherwise, Figma uses your host seat.
These rules apply only while the file is in an active connected folder. If the file is moved out of the connected folder, these rules no longer apply.
How many connected folders can you have?
Your plan determines the number of connected folders you can have in your plan at one time.
| Plan | Number of connected folders |
| Professional | 3 |
| Organization | 6 |
| Enterprise | 15 |
The number of connected folders is inclusive of:
- All connected folders in your team or organization, whether you are the host or the external team.
- Any pending invites to connect where you are the host.
When you disconnect a folder, it no longer counts towards your connected folder count.
How libraries are managed in connected folders
Host admins can curate which of the host’s libraries are available to use in the connected folders. Allowing access to a library grants members of the connected folder view-only access to the library’s source file.
Guests and external users in connected folders
Connected folders also support additional external collaborators, or guests. Both the host and the external team can invite guests into a connected folder. How those users join, and which seat they use, depends on a few factors.
- If the invited user belongs to the connected organization:
- They join the connected folder using the seat type they already have in their own organization.
- If the invited user is from another external organization:
- They join the host organization as a guest.
- By default, they are given a View seat in the host organization.
- If they need a paid seat, any upgrade request is sent to the host organization admin.
Note: Your membership level and assigned seats affect how AI credits and MCP rate limits are determined. See How AI credits and MCP rate limits work in connected folders above.
On the Enterprise plan, guest approval settings still apply to connected folders.
- If the External users can join the organization without restrictions setting is enabled:
- External users invited to the connected folder are automatically added as guests.
- When a guest joins your organization, they join with a free View seat. You can change a guests seat type at any time, and a guest can make a seat request to change their seat type.
- If the External users can only join the organization with admin approval setting is enabled:
- Workspace or organization admins must approve the guest access request before the external user can join the host organization as a guest.
- The user will only be added to the connected folder after approval is granted.
Note: If the connected folder lives inside a workspace, then workspace admins—not just organization admins—may be responsible for approving or managing guest access requests.
Connect a folder to an external team
A folder is connected when the external team accepts an invite from the host. Here’s how the process works:
1. The external team shares their team or organization URL
For a host to create a request to connect, they need the Figma URL of the external team and a contact person’s email address.
Note: To connect a folder, the host and external team must use different business domains—for example, @agency.com and @client.com.
For Professional teams, the domain check applies to all admins on the team, not just the team owner. If any admin's business email domain matches a domain claimed by the other organization, the connection will be blocked. Personal email domains (e.g., gmail.com, yahoo.com) are not considered.
The external team can get their Figma URL by following these steps:
- Log into Figma in a web browser.
- If you're logged into more than one team or organization, make sure the correct one is showing in the left sidebar of the file browser.
- Copy the entire URL in your browser address bar.
- Share this URL with the host admin.
2. A host admin creates the request
On the Organization or Enterprise plan, organization admins can set up a connected folder.
A host admin creates a folder, or chooses an existing folder to connect. This can be any folder in their plan. They create a request to connect from the folder page in the file browser, or from Admin. To send the request, they’ll need the URL of the external team and a contact person’s email address.
- From the file browser, navigate to the folder you'd like to connect.
- Click Settings in the top right of the screen.
- Click Connect an external team.
- From the file browser, click Admin.
- Select Content.
- Click the Connected folders tab.
- Click Create a connected folder and search for the folder.
3. An external team admin approves the request
Admins of the external team get notified about the request to connect, and can approve or decline the connection.
Once accepted, the contact person on the external team is added to the folder. This person can invite more people from the external team to the folder.
People on the external team can start working in the connected folder by switching to the host’s team or organization in the file browser sidebar.
Disconnect a connected folder
When a project comes to an end, an admin from either party can disconnect the folder. When a folder is disconnected, it remains in the ownership of the host. The external team will lose access to all the files in the folder.
Host admins will be asked if they would like to share the folder with the external team. They can:
- Do nothing. The external team will lose access to the folder once it is disconnected.
- Share a copy of the folder. The host keeps the original folder and sends a copy to the external team.
Tip: You can always share a copy of the folder—or transfer it completely—at a later date.
