Before you start
Who can use this feature
Available in Figma Design and Figma Slides
Available on paid plans
Requires can edit file access
Find the components or assets that you're looking for with Figma AI, so you can get started faster, stay in the flow, and make space for more creativity.
For example:
- Get inspired through related designs and see how others are thinking about a design problem
- Browse through past explorations to help finish an in-progress design
- Find the latest source of truth for a component
There are two ways to use AI in search:
- Find similar designs: Use descriptive prompts, an image, or a canvas selection to find related components and designs.
- Assets tab: Use a keyword search to find components without needing to remember their exact names.
With Find similar designs, you can find components and non-component elements using a keyword or descriptive prompt, a layer selection, or an image. If you find one you like, you open the source file or insert it onto the canvas without leaving your current file.
Search by keywords
- From the toolbar, click Actions.
- Type keywords or a description into the search bar and select the Figma/Community filter.
- From the search results, use the Figma tab to find components and other designs, or use the Community tab to search through Figma Community files.
Search from a canvas selection
- Select a layer.
- Click Actions from the toolbar and select Find more like.
Search using an image
- Click Search with image or selection.
- Select a layer with an image fill. Or click Upload to upload an image from your computer, then click Search.
Navigate results
There are two tabs you can use to browse from the results view. The Figma tab shows components and other design assets from files available to you. The Community tab shows designs available in Figma Community files. Each tab has a different search result experience:
If you’re in the Figma tab, use the dropdown on the right to filter by library.
When you click See more next to Other designs, you can narrow and sort your results:
- Filter by file owner
- Filter by space
- Sort by relevance
- Sort by last modified
When you select a design from the list, you can choose to:
- Open the file where the design lives in a new tab
- Preview the design in the current tab
- Insert the design into the current file
When you select a design in the Community tab, you can choose to:
Find components from the Figma tab
Figma uses AI to return smarter results and help you find what you’re looking for, so you don’t have to remember the name of that one component.
Without AI
Without AI, Figma tries to match your search terms to exact keywords in a component’s name or description. For example, if you searched arrow Figma would only return components with the word “arrow” in its name or description.
With AI
With AI, Figma looks for exact names as well as related components. For example, searching arrow would return components with “arrow” in their name and descriptions, as well as components that are similar in form or function.
You can search for assets either from the assets tab in the left panel, or by using Actions from the toolbar.
