Figma AI helps you explore ideas, create and refine content, and spend less time on repetitive tasks.
There are many ways to use AI in Figma. The examples below give you a general idea of what each feature can help you do. Many workflows overlap, and you can combine tools as you explore and refine your work.
| What is it? | What might you use it for? | |
| The Figma agent | A conversational AI tool you can work with directly in Figma files | Generate and edit designs, use and document your design system, get feedback |
| Figma Make | A prompt-to-app tool for creating functional prototypes and web apps from prompts or existing designs | Build and refine and interactive app or prototype in its own Figma Make file |
| Code layers | Layers that run working code on the Figma Design canvas, alongside your design | Try interactive ideas and compare working prototypes in the same design file |
| Individual AI tools | Focused AI features built into Figma products for specific tasks | Complete a specific task, such as rewriting copy, editing a single image, or summarizing sticky notes |
Tip: Work with Figma from other AI tools
You can use the Figma MCP server to connect Figma to AI tools such as Claude Code, Codex, and Cursor. Give your AI tool design context to help generate code, or ask it to create and update designs in Figma.
You can use Figma AI across different Figma products as a part of your workflow for each stage of the development process. For example, you might:
- Explore your ideas with AI in FigJam: Generate a board, then sort and summarize the team’s sticky notes to identify themes and next steps
- Use AI to develop designs in Figma Design: Ask the agent to generate a screen using your team’s library, then create a code layer to try an interaction alongside your designs
- Build a functional prototype in Figma Make: Start from a prompt, existing design, or repo, then refine the prototype to test an idea with your team
- Build a presentation in Figma Slides: Turn a FigJam board into a starting point for your deck, adjust the copy for your audience, and draft presenter notes
Learn more about each feature and who can use it below. You’ll also find guidance on why you might not have access to AI features and best practices when using AI tools.
Work with the Figma agent
The Figma agent is a conversational AI tool you collaborate with in Figma files.
Describe what you want in plain language, then review the results and ask for changes as you work:
- In Figma Design, generate and remix designs, automate busywork, and get design feedback.
- In FigJam, generate boards and diagrams, organize or summarize board content, and turn ideas into next steps with your team.
- In Figma Slides, turn ideas and source material into presentations, review and refine outlines, and make changes to slides with your team.
Who can use the Figma agent?
In Figma Design, the Figma agent is available on Starter, Professional, Organization, Enterprise, and Education plans. Education plan access is limited to higher education and bootcamp users.
In Figma Design, your seat and file access determine how you can work with the agent:
- In shared files: Users with Full seats and edit access can chat with the agent and ask it to make edits. Users with Dev, Collab, or View seats—or view-only access—can ask the agent questions, but can’t use it to edit the file.
- In Drafts: Anyone can chat with the agent and ask it to make edits in their own draft files
In FigJam and Figma Slides, the agent is available on Professional, Organization, and Enterprise plans. Anyone with access to a board or presentation can chat with the agent about its contents. Asking the agent to make changes requires edit access.
Explore interactive ideas with code layers
Code layers bring working code onto the Figma Design canvas, alongside your designs. Start with a prompt or an existing design to create an interactive prototype, then try it directly on the canvas.
Use code layers to explore how an idea behaves, compare different approaches, and refine an interaction with your team. You can duplicate a code layer to try another direction and keep the alternatives next to each other.
You can work with the Figma agent to create and refine code layers as part of your design workflow.
Learn more about using code layers.
Who can use code layers?
Code layers are available on Starter, Professional, Organization, Enterprise, and Education plans. Education plan access is limited to higher education and bootcamp users.
Code layers are available in Figma Design and is currently in open beta.
Your seat determines how you can use code layers:
- Full seats: Full access
- Dev, Collab, and View seats: Can explore code layers in drafts
Build with Figma Make
Figma Make is a code editor for prototyping on your codebase or from scratch. Start with a prompt or an existing design, then work in a dedicated Figma Make file to preview and refine the result.
Describe changes in the chat, use the editing tools and annotations to adjust specific elements, or edit the code directly.
Use Figma Make to:
- Preview the look and feel of your designs in a functional form
- Turn proposals and ideas into prototypes to help hone your product approach
- Explore a variety of solutions for a problem you're trying to solve
Tip: Figma Make and code layers both let you create with AI-generated code. In Figma Make, you work in a dedicated file and can publish your app as a website. With code layers, you can explore interactive ideas alongside designs on the Figma Design canvas.
Who can use Figma Make?
Figma Make is available on Starter (with limitations), Professional, Organization, Enterprise, Education, and Government plans. Education plan access is limited to higher education and bootcamp users.
Your seat determines which features you can use:
- Dev seats: Can explore Figma Make in Drafts and export code from Figma Make files.
- Collab and View seats: Can explore Figma Make in Drafts.
Learn more about Figma Make availability.
Use individual AI tools
Individual AI tools are focused features built into Figma's products. Each AI tool does one specific thing, right where you need it.
Use the table below to find a tool for your task and see which products support it. Plan and seat requirements are explained after the table.
| What can it help you do? | Products | |
| Rewrite, translate, or shorten text | Adapt copy for a different audience, preview another language, or fit a smaller space | Figma Design, FigJam, Figma Sites, Figma Buzz |
| Adjust tone | Rephrase content for a different audience | FigJam, Figma Slides |
| Make or edit an image with prompts | Create or edit a visual from a written prompt | Figma Design, FigJam, Figma Slides, Figma Sites, Figma Buzz |
| Remove background | Place a subject over a different background | Figma Design, FigJam, Figma Slides, Figma Sites, Figma Buzz |
| Expand image | Extend a visual to fit a different layout | Figma Design, FigJam, Figma Slides, Figma Buzz |
| Isolate or erase object | Reuse a selected object or remove an unwanted detail | Figma Design, FigJam, Figma Slides, Figma Buzz |
| Vectorize image | Turn a static illustration into editable vectors | Figma Design, Figma Slides, Figma Buzz |
| Boost resolution | Improve a low-resolution image’s clarity | Figma Design, FigJam, Figma Slides, Figma Sites, Figma Buzz |
| Replace content | Populate repeated cards or lists with realistic text | Figma Design, Figma Sites |
| Rename layers | Give layers descriptive names | Figma Design |
| Add interactions | Connect designs into an interactive prototype | Figma Design |
| AI search | Find existing designs, assets, or slide decks | Figma Design, Figma Slides |
| Generate boards and diagrams | Prepare a meeting board, diagram, timeline, or project plan | FigJam |
| Sort and summarize stickies | Group ideas by theme or summarize a discussion | FigJam |
| Jambot | Brainstorm, reframe text, explore a topic, or generate code in a widget | FigJam |
| Generate a slide deck from a FigJam board | Turn board content into a presentation starting point | FigJam → Figma Slides |
| Draft presenter notes | Create speaking notes from a slide’s written content | Figma Slides |
| Weave tools | Generate image variations, retouch a photo, or apply a visual style using tools built by Figma and the Community | Figma Design |
Who can use individual AI tools?
Individual AI tools are available on Professional, Organization, Enterprise, and Education plans. Education plan access is limited to higher education and bootcamp users.
There are some exceptions:
- Starter plans: Users on the Starter plan can access image tools in Figma Design, including making and editing images, removing backgrounds, expanding images, isolating or erasing objects, vectorizing images, and boosting resolution.
- Figma Buzz beta: AI tools in Figma Buzz are available to users on all plans while Figma Buzz is in beta.
To use individual AI tools in shared files, you need edit access to the file and a seat that supports the product:
| Product | Seats |
| Figma Design | Full |
| FigJam | Full, Dev, Collab |
| Figma Slides | Full, Dev, Collab |
| Figma Sites | Full |
| Figma Buzz, during beta | Full, Dev, Collab, View |
Users with Full, Dev, Collab, or View seats can try AI tools in all products in Drafts, subject to the feature’s plan requirements. If you try a product that isn’t otherwise included with your seat, you’ll need to upgrade before sharing the file with a team or moving it into a folder.
Why don't I have access to AI features?
If an AI feature isn’t available in your account, check the following:
- Your plan, seat, or file access: Requirements vary by feature and product. Review the availability information above.
- Your team or organization’s AI settings: An admin may have turned off AI features. Contact your admin if you have questions.
- Your Education account type: AI features are available to higher education and bootcamp Education users. They aren’t available to K–12 Education users.
- Figma for Government: Figma Make is available to organizations using Figma for Government, but other Figma AI features aren’t currently available.
- Beta or rollout access: Some features are limited to beta participants or are gradually rolling out.
If you can access a feature but can’t generate more results, check your AI credit usage.
For help with an error or unexpected behavior, see Troubleshoot AI tools in Figma.
Best practices when using AI tools
When it comes to building AI, we want to be transparent about what we’re doing and what this means for you. Learn more about Figma’s approach to AI.
There are a few things to keep in mind when using any AI tool:
Accuracy
AI-powered tools are designed to provide information and results based on artificial intelligence algorithms, and identify patterns and relationships from large amounts of data. It’s important to note that the accuracy and reliability of these results may vary.
There is a possibility of inaccuracies, omissions, or misleading outcomes due to the complexities and limitations of AI technologies. Therefore, the information provided by the tool should be regarded as a general reference and not a fact or a substitute for expert advice or your own research.
Your responsibilities
- You should exercise your own judgment and discretion when using AI-powered tools. It’s essential to verify and cross-check the information provided by the tool before making any decisions, taking actions, or relying on it for critical matters.
- You should let others know when you’re using or presenting AI-generated outputs. For some features, like summarize stickies, Figma will indicate when an output is AI-generated.
- You will only use AI features in accordance with Figma’s Acceptable Use Policy.
