Before you start
Who can use this feature
Available in FigJam and Figma Slides
Available on paid plans
Requires can edit file access
You can use Figma AI to adjust the tone of any text within your file. Quickly rephrase, condense, or expand content to reduce manual rewriting and keep your tone consistent.
Use Adjust tone
To use Adjust tone in FigJam or Figma Slides:
- Select a text layer.
- From the bottom toolbar, click Actions > Rewrite this.
- On the prompt box, click Adjust tone.
- Drag the tone dial inside the axis or choose a tone preset: Executive, Technical, Basic, or Educational. Figma AI will attempt to detect the language you’re using and adjust the text accordingly.
- If you aren’t happy with the adjusted text, click Try again to rewrite the text again. To undo the changes, click Reset in the adjust tone axis.
