Before you Start
Who can use this feature
Image uploads and YouTube embeds are available on any plan
Video uploads are available on any paid plan
Anyone with can edit
access to the slide deck can add media to a slide
You can insert photos, graphics, videos, and GIFs to your slide deck and replace media placeholders with your own visuals.
Figma Slides supports the following formats:
- Image: JPG, PNG, HEIC, WebP, SVG, GIF, TIFF (only available on Safari)
- Video: MP4, MOV, WebM
Note: When you upload an SVG to Figma Slides, it is no longer treated as an image and cannot be used to fill media placeholders. Instead, SVGs are converted to editable vector layers.
Add an image or video to a slide
Drag and drop files from your computer into Figma Slides, or use the media picker to select the files you want to add. You can import multiple files at the same time.
- Click Image/video in the toolbar or use the keyboard shortcut:
- Mac: Shift Command K
- Windows: Shift Ctrl K
- The media picker opens. Select the files you’d like to add to your slide deck and click Open.
- Your cursor will show a thumbnail of the first file. If you selected multiple files, a badge displays the number of files you have left to place.
- Do one of the following:
- Click on an area of a slide or the canvas to add the file to those coordinates. Figma Slides will add the file at its original dimensions.
- Click and drag to define the dimensions of the file. This allows you to add the file with dimensions that are different from the original file.
- Hover your cursor over an object with a fill, such as text or shapes, and click to replace the fill with your file.
Once added, you can use the Fill section in the right sidebar to adjust how your visual looks. Learn more about adjusting image or video properties.
Note: Animated GIFs display as static images when viewing a deck in the Figma Slides editor. To play an animated GIF, open the deck in presenter view.
Add an image or video to a media placeholder
Some templates include slide layouts with media placeholders. Media placeholders let you easily add your content without impacting other objects on the slide. You can identify media placeholders by their white and gray checkered fill.
To replace a media placeholder:
- Select the media placeholder.
- Click Image/video in the toolbar or Choose media in the right sidebar.
- Select the file you want to import.
- Click Open.
The file will be added to the media placeholder as a fill. You can use the Fill section in the right sidebar to adjust how your visual looks. Learn more about adjusting image and video properties.
Embed YouTube videos
You can embed YouTube videos in your slide deck and play them during your presentation.
Note: YouTube videos cannot be used as object fills.
- Copy the video link from YouTube.
- Right-click on a slide and select Paste here or use the keyboard shortcut:
- Mac: ⌘ Command V
- Windows: Control V
- With the video selected, use the handles to reposition or resize the video. Embedded YouTube videos are a top-level layer and cannot be overlapped by other objects on the slide.
While presenting, use the video controls to play, pause, or go to a specific timestamp.
Note: You must be connected to the internet to play embedded YouTube videos.
