Who can use this feature
Professional, Education (not K-12), Organization, and Enterprise plans
Requires view access to the source FigJam board
After hosting an engaging team brainstorm or user research session in FigJam, you may have a lot of content to sift through before you can share your findings in a Figma Slides deck. With Figma AI, you can generate a slide deck from a FigJam board, giving you a good starting point that you can use to build the rest of your presentation.
Generate a slide deck
You can generate a slide deck from any FigJam board you have can view access to. There are a few ways to generate a slide deck:
From Figma Slides
Note: To generate slides in an existing slide deck, you need edit access to the file.
- Click New slide in the left sidebar to open the template picker.
- Click Make Slides with an outline.
- Choose a FigJam board to summarize.
- If the FigJam board you selected has multiple pages, use the dropdown menu to select a specific page or choose All pages to summarize the entire board.
- Click Next.
- Select a template to use for the deck or click Create deck without template.
Figma AI sorts and summarizes the content on the FigJam and generates a slide deck. You can modify the generated slides and add additional slides to the deck, as needed.
From FigJam
- Open the board you want to use.
- Do one of the following:
- Go to Main menu > File > Turn FigJam board into deck
- Click More actions next to a page and select Turn FigJam board into deck
- Click Share in the top toolbar and select Turn FigJam board into deck
- Select sticky notes on the board, right-click and select Turn FigJam board into deck
- You’ll be redirected to the template picker in Figma Slides. Select a template to use for the deck or click Create deck without template.
Figma AI sorts and summarizes the content on the FigJam board and generates a slide deck. You can modify the generated slides and add additional slides to the deck, as needed.
