Use the eyedropper tool to apply colors to layers by sampling colors from any layer, image, or background image of a page. You can even sample, apply, and create color variables and color styles using the eyedropper.
Toggle the eyedropper tool
There are a couple of ways to toggle the eyedropper tool depending on the property for which you want to update the color.
Toggle eyedropper for color fill property
- Select the layer you wish to edit.
- Select the eyedropper tool by using the keyboard shortcut:
- Mac: ⌃ ControlC or I
- Windows: I
Note: If you’re using Mac, you can also use ⌃ ControlC to toggle the eyedropper tool. This can be useful if, for example, you’re editing a text layer and want to toggle the eyedropper tool without adding text content.
Toggle eyedropper for other properties
This method works for all properties containing color, such as stroke, shadow effects, and colors in a mixed selection.
- Select layer you wish to edit.
- In the right sidebar, find the property you wish to edit and click the color swatch to open the color picker.
- From the color picker, click the Eyedropper icon or use the keyboard shortcut:
- Mac: ⌃ Control C or I
- Windows: I
Sample and apply a color
With the eyedropper tool toggled, you can sample and apply colors from any layer or background of the current page. You can also sample and apply color variables and color styles.
Raw color value
- Select the layer you want to edit.
- Toggle the eyedropper tool, then hover over a layer to view information about the color’s appearance, color, and value. If desired, you can switch between different color models.
- Click on the color to apply it to the selected layer.
If you're using the Figma Desktop app for macOS, you can sample colors from anywhere on your screen. To get started:
- Toggle the eyedropper tool.
- Hover outside the Desktop app window and click anywhere.
- You'll be asked to enable the Screen & System Audio Recording permission in macOS. This permission is required by macOS to access your screen outside the Figma app.
- Click Request permission and follow the prompts.
Once enabled, you'll be able to hover and click to select any color on your screen, be it an image, another app, or something on a website.
Note: Sampling colors outside the canvas is currently only supported when using versions 126.2.10 or newer of the Figma Desktop app / 126.3.6 or newer of the beta version of the Figma Desktop app for macOS 14 or newer. It is not currently supported on the Figma Desktop app for Windows or Figma on a browser.
Color variable or style
You can use the eyedropper tool to sample a color variable or style and apply it to a selected layer.
- Toggle the eyedropper tool, then hover over a pixel containing a color variable or color style.
- While holding ⇧ Shift, click on the layer to apply the variable or style to the selected layer.
Switch between color models
While sampling a color with the eyedropper tool, you can press Tab on your keyboard to switch to view the color values in a different color model.
You can switch between Hex, RGB, HSL, and HSB. Learn more about color models.
Create a color variable or style
You can use the eyedropper tool to create a color variable or style from a sampled color.
- Hold the following keyboard shortcut:
- Mac: ⌘ Command ⇧ Shift
- Windows: ⌃ Control ⇧ Shift
- While holding the shortcut, press Enter or click on the color from which you wish to create a color variable or style. .
- From the modal, use the tabs to choose whether to create a Style or Variable.
- Fill out the fields and press Create. This will create the style or variable and apply it to the selected layer.
Copy a color to the clipboard
To copy the color values of a sampled pixel:
- Deselect everything on the canvas by pressing Esc on your keyboard.
- If desired, press Tab to switch to a different color model.
- Click anywhere to copy the color information to your clipboard. If a color variable or color style is applied, you can hold ⇧ Shift to copy the variable or style name and color value.
