Vector paths may sometimes include more vector points than necessary, which can make the path look rougher than intended and impact file performance . You can simplify a vector path to remove unnecessary points, creating a less complex path while maintaining the original shape’s integrity.
Simplifying a vector path is a destructive action, meaning that once a path is simplified, you cannot revert it back to the original shape. If you simplify a vector path by mistake, you can use the file’s version history to restore a previous version or use the undo shortcut:
- Mac: Command Z
- Windows: Ctrl Z
Simplify a vector path automatically
You can use the Simplify vector tool to simplify an entire vector path at once.
- Select the vector layer you wish to modify.
- Select Simplify vector.
- Use the slider to determine how simple the new path should be.
Simplify a vector path manually
For more precise control, you can use delete and heal to fine-tune specific areas of a vector path.
- Press Enter to open vector edit mode.
- Use the Lasso tool to select a group of points. Keep in mind, every point you select will be involved in the path simplification process. Deleting and healing too many points can result in an over-simplified shape.
- Hold Shift and press Delete to delete and heal the selected points.
- Press Enter to close vector edit mode.
