Who can use this feature
Starter, Professional, Education (not K-12), Organization, and Enterprise plans
Tip: You can also build a content-driven website in Figma Make using Payload, a content management system (CMS). Describe the website you want in the chat, then manage its content through the CMS tab. Learn how to use Payload in Figma Make.
A CMS page is a dynamic webpage that displays individual items from a collection. It lets you design a single layout and automatically populate it with content—such as an article, product, or case study—pulled directly from your CMS.
This means you can publish multiple pages using the same design template without duplicating, rebuilding or adjusting the layout each time.
In a CMS page, each item’s slug is appended to the webpage’s URL path. For example, if you convert the /reviews page into a CMS page, each item will appear at a URL like /reviews/sgt-peppers-lonely-hearts-club-band.
What’s the difference between a CMS page and a CMS list?
Suppose you’re working on a cooking website with lots of recipes.
A CMS list displays multiple items from a collection—like a grid of recipe previews with titles, images, and short descriptions. Visitors can browse through the list to find what they’re interested in.
A CMS page shows all the details for a specific item: the ingredients, steps, and photos. Each CMS page uses the same design template, but the content updates automatically based on the selected recipe.
Insert a pre-built CMS page block
Note: You’ll need to create a CMS collection before you can add CMS blocks.
If you’re starting from a blank webpage for your CMS, we recommend inserting a pre-built CMS page block. This block is already connected to your CMS, and just needs to be styled:
- Click Insert from the left navigation bar.
- From the Blocks tab, click CMS.
- Drag a CMS page onto the canvas for the relevant collection.
- Style the elements containing your content, and add any new design elements as needed.
Tip: If your collection contains a rich text field, learn more about how to style it.
Create your own CMS page
If your webpage already contains design elements, you can convert it into a CMS page by connecting it to a collection, then connecting its layers to fields in the collection.
Note: You can’t turn the Home page into a CMS page.
To create a CMS page:
- Select the webpage on the canvas.
- In the right sidebar, click CMS and select a collection.
Tip: You can also create a CMS page from Connect view. Click CMS in the left navigation bar, then switch to the Connect tab at the top of the left sidebar. Hover over a collection name, click Connect, and select Full page. Then, click your webpage to connect it.
With the page connected, you can now switch between collection items in the webpage header. Notice how the page content doesn’t change as you switch between items? To make it dynamic, follow the steps below to connect the CMS collection to layers on the page.
Connect layers to CMS fields
After your webpage is connected to a collection, connect individual layers to CMS fields so the design updates automatically for each item.
Note: You can only connect CMS fields to layers within a CMS page or in a CMS list.
Connect layers from the right sidebar
You can quickly connect layers from the right sidebar while working on the webpage. This process is similar to working with variables.
Connect to a text layer
- Select a layer. For text layers, make sure you select the actual text layer and not any parent layers, like a frame.
- At the top of the right sidebar, click Apply variable or CMS field, then select a field.
Connect to an image fill
You can connect an image field to any layer with a fill, like shapes and frames.
- Select a layer with a fill within the CMS page.
- In the Fill section of the right sidebar, click Add fill.
- Select the CMS tab, then select an image field in the collection to connect it.
Connect a link
You can connect a link field to any linkable element, like text, frames, or shapes.
- Select a layer within the CMS list.
- In the right sidebar, click Add link.
- Enter a link, or open the dropdown menu to select an existing webpage from your site.
Tip: This is how you link a CMS list to a CMS page.
Connect layers in Connect view
Connect view helps you wire up an existing layout or review what’s already connected. In this view, you choose a field, then select the target layer in the webpage to connect it.
Note: Certain field types only connect to compatible layer types. For example, you can’t connect a text field to a shape or frame.
- Click CMS in the left navigation bar.
- Select the Connect tab.
- Click a field in the collection, then click a target layer in the CMS page to connect it.
- Repeat for additional fields and layers.
Note: If you can’t connect a field to a layer, make sure you’ve already created the CMS page.
Tip: While in Connect view, double click a connected design on the canvas to edit the field values for the current item.
Preview items in the CMS page
Once layers are connected, you can preview how the page looks for different items in the collection.
Click the slug in the header of the CMS webpage to switch between items.
Tip: You can also click Preview to view the page in a full screen preview, or press Shift Space to open the inline preview.
Note: You can’t preview a CMS page while in Connect view.
Remove a connection
To disconnect a layer or CMS page:
- From the left navigation bar, click CMS and switch to the Connect tab.
- Click the collection name in the header of the webpage, or a connected layer, and select Remove connection.
When you remove a connection, the disconnected page or layer keeps its last known content but no longer updates dynamically.
Tip: You can also disconnect a layer from the properties panel. Select it on the canvas, then click Remove connection in the right sidebar.
Frequently asked questions
What happens if an item has an empty field when connected to a layer?
- An empty text or date field causes the text layer to render with no content.
- An empty image field translates to an empty, transparent fill on the frame or shape. To make sure an image always shows, apply a fallback fill below the connected fill, so an image still appears if the CMS field is empty.
Can I connect components to CMS fields?
You can connect component instances in a CMS page to fields in a collection. Connect their text layers, image fills, and linkable parts as needed. You can’t connect a main component, as these aren’t allowed inside webpages.
What happens if I duplicate a connected layer?
Duplicated layers remain connected unless they are duplicated outside of the CMS page or list. You can always remove the connection and reconnect to a different field as needed.
What happens if I move a connected layer outside the CMS page?
When a connected layer is moved outside the CMS page—onto the canvas or into a different webpage—it loses its CMS connection. The layer retains its last known content but will no longer update dynamically.
