Duplicate a File
Before you Start
Who can use this feature
Users on Any Figma plan
Anyone can Duplicate Files in their Drafts
Viewers, Editors and Admins can duplicate Files in a Team
Viewers won't be able to duplicate a File if Allow Viewers to copy and share is disabled
Duplicating a File will create a fresh copy of that File. This won't include any of the following from the original File:
- Version History
- Comments
- Collaborators and Permissions
You can duplicate a File from anywhere in the File Browser. We will add a duplicate of the File to the File's current location. This applies to Files in your Drafts or within a Project in a Team.
We'll add a Copy of
prefix to the File name, so you can distinguish between the original and the duplicate.
Want to duplicate a File from the Community? Check out our Browse and Duplicate Community Files article.
Duplicate a File
- Right-click on the File to open the File menu.
- Select Duplicate from the options.
Tip! You can also duplicate a File by adding /duplicate
to the end of the File URL. This will only work with the original File URL.
If you have layers selected, you will need to remove the node string from the URL first e.g. ?node-id=21%3A0
Duplicate a Deleted File
You can duplicate a File in your Deleted Files. We will add this duplicate to your Drafts folder.
- Open your Drafts in the File Browser.
- Navigate to the Deleted Files tab.
- Select Duplicate to Drafts to create a copy of the File in your Drafts. We treat this as a new File with no Permissions, Comments or Version History.
