Manage and share styles
Before you start
Who can use this feature
Supported on any team or plan.
Anyone with can edit access to a file can create and edit styles.
Anyone with can view access to a published file can use styles from that library in files they can edit.
Styles allow you to define a set of properties or attributes of an object. You can create styles for colors, text, effects, and layout grids so you can reuse them across your designs.
View styles
Local styles are styles that exist in the current file. You can access local styles in the right sidebar when nothing is selected, or from the style picker.
To view styles from other published files, you can view them in the style picker for a selected property. Learn more about enabling libraries in a file →
Right sidebar
Once you have created at least one style within a file, you can view them in the Local styles section of the right sidebar.
You'll need to make sure you have nothing selected in the canvas first:
- Click on an empty spot in the canvas
- Press
Esc
to deselect your current selection
View any local styles in the Design panel of the right sidebar. Figma groups styles by type:
- Text
- Color
- Effect
- Layout grid
Style picker
View local styles, and styles from other libraries, in the style picker.
Click the styles icon next to the relevant property in the right sidebar. Figma will open the style picker which lets you to view any styles available for that property.
The default order for styles in the style panel is:
- Alphabetically by team name
- Alphabetically by file name
- Individual styles are in the same order as they appear in the right sidebar
You can toggle between list and grid views
Manage styles
To make changes to a style, you will need to edit the style definition in its original file. It's not possible to make changes to the style from another file.
Tip! Access the original style when you view the style in the right sidebar. Right-click the style and select Go to style definition to open the file and edit the style there.
Group styles
To make finding and selecting styles easier, you can organize your styles into groups. This can be done by using the /
naming convention and by creating folders.
Group by folder
You can group styles by creating folders from the Design tab of the right sidebar. Folders will be reflected from the Local styles section of the right sidebar and in the style picker when you click for a given property.
To create a folder:
- Select one or more styles. Use
Shift
+click
to select a range styles, orCommand
/Control
+click
to select multiple non-adjacent styles. - Right-click the selected style(s) and click Add new folder.
- Name the new folder and press
Return
/Enter
to save.
Once created, the styles in the folder will be renamed according to their new heirarchy within the styles list. In the example below, the style Brand / Fuchsia was moved to the Blog folder within the Brand folder, which renamed the style to Brand / Blog / Fuchsia.
To delete a folder and the styles in it, right-click the folder name and select Delete. You can also move all styles to another location to keep the styles and delete the folder.
Group by name
Grouping styles using the slash naming convention involves adding a prefix to your style names so Figma groups them under the same heading.
In the example below, we use the slash naming convention to name and organize our styles:
- Blog/
Color
- Brand Style Guide/
Color
- Secondary/
Color
Tip! Styles appear in the styles panel in the order they appear in the Local styles list. To change the order your styles appear, you can update by clicking and dragging them in the Local styles list from the file in which they were created.
Reorder and move styles
When you view the Local styles section in the right sidebar, you can see every style in the current file, grouped by the style type: text, color, effect, and layout grids.
By default, Figma will show styles in the order they were added. To make them easier to find and navigate, you can change the order they appear.
Shift
+click
/Control
+click
to select multiple non-adjacent styles. - Drag the style to change the order or move them to a new folder.
- Release the mouse.
- Repeat for any other styles.
Reordering and moving styles also changes the name for the style to reflect its place in the hierarchy. For example, moving the color style Brand Style Guide / blue to the Blog folder will also change the style name to Blog / blue.
Note: You can only adjust the order for local Styles, Figma sorts styles in the style picker differently.
Edit styles
You can edit local styles from the right sidebar and from the style picker.
- Right sidebar: hover over the style, then click the adjust icon when it appears.
- Style picker: right-click on the style and select Edit style from the options.
View styles and their properties at the top of the Edit style panel.
- View or update the Name of the style.
- Add or update the style description, which displays when hovering over the style in the style picker.
- View or make changes to any properties of the style.
- Click on the icon to hide or show the property on any objects the style is applied to
- Click the icon to remove the property from the style
Any changes you make to the style here will update any objects in the file that use this style.
Delete styles
If you would like to remove one or more styles, you can do this directly from the panel.
Shift
+click
/Control
+click
to select multiple non-adjacent styles. - Select Delete style or Delete all from the options.
- Figma will remove the style and you will no longer be able to use it. Any objects using that style will keep their properties, but are detached from the style.
Share styles
To access your styles in other files and projects, you can publish them to a team library. You can publish styles on their own, or alongside any components.
You can publish styles in a free Starter teams plan, but not components. You will need to be on the Professional or Figma Organization plan to publish components.
Publish styles to a library
- Open the Assets panel in the left sidebar and click the Team Library icon. Or, use the keyboard shortcuts:
- Mac: ⌥ Option + 3
- Windows: Alt - 3
- In the Current file section, click Publish next to the file name.
- Add a description of the changes you've made to the file. Figma will include your description in the version history of the file.
- Click the icon next to Styles and components section to view a list of all styles and components.
- Click Publish to share them as a library.
When you publish changes to a library, Figma will prompt anyone using this library to receive updates. This makes sure any layers that use these styles use the most recent version.
Use Styles from a library
When you enable a library for a file, anyone with can edit
access to that file can access those styles and components.
- View any style from that library in the style picker.
- View any styles from that library as a separate palette in the color picker.
- You can use any styles that are shared with you. Learn how to apply styles →
- You can only edit styles that live in files you have
can edit
access to.
