Add images and videos in bulk
If you're using UI3, Figma's new design, some parts of this article might not match what you see in the product today. We appreciate your patience while we make updates. Learn more about Figma’s redesign →
Who can use this feature
Adding images is supported on any team or plan. Adding videos is supported on any paid team or plan.
Only people with Can edit access to the file can add images.
Place image/video allows you to import images and/or videos in bulk. You can then choose exactly where you'd like to place each file. As Figma treats images and videos as fills, you can add them to existing objects.
Tip! Figma supports .png, .jpg, .tiff, or .heic image files, and .mp4, .mov, or .webm video files. Learn more about working with videos in Figma →
Note: If you are on the Starter plan, you can only add images—this means that instead of “Place image/video,” your menu item is labelled “Place image.”
- Access Place image/video from any of the following places:
- From the menu, by searching Quick actions for Place image/video.
- From the Shapes menu in the toolbar:
- Use the keyboard shortcuts:
MacOS: Shift-Command-K
Windows: Shift + Ctrl + K
- Figma will open an upload window which allows you to select your image and/or video files. Select the files you'd like to use and click Open.
- Figma will show a plus cursor and a thumbnail of the first file. If you've selected multiple files, a badge will show how many files you have left to place.
- You then have a few options:
- Click on an area in the canvas to add an image/video to those co-ordinates. Figma will add the file to the canvas at its original dimensions:
- Click and drag to define the dimensions of the image/video. This allows you to add the file with dimensions that are different to the original.
- Select an existing object on the canvas. This will apply the image/video as a fill with the Fill mode set to Fill.
- Select Place all in the menu bar to add all files to the canvas at once.
- Repeat the process for any remaining images/videos. Use the Discard all button in the menu bar to discard any files that haven't been placed.
Having issues loading images? Learn about the most common image loading issues and how to fix them.
