Who can use this feature
Adding images is supported on any team or plan. Adding videos is supported on any paid team or plan.
Only people with Can edit access to the file can add images.
Place image/video allows you to import images and/or videos in bulk. You can then choose exactly where you'd like to place each file. As Figma treats images and videos as fills, you can add them to existing objects.
Tip! Figma supports .png, .jpg, .tiff, or .heic image files, and .mp4, .mov, or .webm video files. Learn more about working with videos in Figma →
Note: If you are on the Starter plan, you can only add images—this means that instead of Place image/video, your action and menu item is labelled Place image.
- Access Place image/video from any of the following places:
- From the menu, by searching Actions for Place image/video.
- From the Shape tools menu in the toolbar.
- Use the keyboard shortcuts:
MacOS: Shift-Command-K
Windows: Shift + Ctrl + K
- In the file browser that Figma opens, select multiple image and/or video files you'd like to use, and then click Open.
The cursor gets a badge showing the number of images that need to be placed. - A thumbnail of the current image to place appears next to the cursor. You then have two options:
- Click on the canvas to add the image/video. Figma adds the image/video to the canvas where you clicked, using its original dimensions.
- Select an existing object on the canvas. The image/video is applied as a fill with the Fill mode set to Fill.
- Repeat the process for any remaining images/videos. To discard any remaining videos or images, press Esc.
Having issues loading images? Learn about the most common image loading issues and how to fix them.
