Figma Motion is currently in open beta. Features may change and you may experience performance issues as we continue to improve Figma Motion. Learn more about what's included in the beta.
Before you Start
Who can use this feature
Available on any plan
Anyone with can edit access to a file can add animations
Figma Motion includes preset animations that let you quickly add motion to your designs without manually configuring keyframes. Use individual animations for basic movement, or apply a composite animation style to add complexity to your motion.
Note: You can also create and publish custom animation styles to build motion that is consistent with your motion design system. Learn more about custom animation styles.
Apply a preset animation
- In Figma Motion, select the layers you want to animate.
- Click the plus in the Animations section of the right sidebar to add a new animation.
- Choose an animation type from the menu, then use the settings to configure the motion. Available settings vary depending on the animation type selected.
Note: Text animation styles are coming soon.
Apply a composite animation style
Composite animation styles apply multiple preset animations at once, so you can create more complex motion without building it from scratch.
- Click Animations in the Animations section of the right sidebar to add a new composite animation style.
- Choose a composite animation style from the list. This applies multiple preset animations to your selected layers.
- Select an individual animation on the timeline or in the Animations section to further configure the motion.
Move animations in time
When you apply a preset animation, it appears on the timeline starting at the current playhead position. You can click and drag the animation to move it to a different time, or drag the handles to adjust its duration.
Update an animation
You can access an animation’s settings by selecting it on the timeline or clicking it in the Animations section of the right sidebar. From there, you can update the animation type, adjust animation-specific settings, modify the duration, and update the easing.
Getting started with animation? Visit the Motion design fundamentals collection to learn the principles behind effective motion design and get hands-on practice creating animations in Figma Motion.
For more interactive learning experiences, check out the Figma Motion playground file on the Figma Community.
