Figma has a number of features under development that are available to users in beta. In this article, find out which beta features are available, what they are, and how to access each one.
Note: Beta features can change during the beta period. You may experience bugs or performance issues during this time.
Figma MotionOpen beta
Before you start
Who can use this feature
Available for Full seats on all plans
Figma Motion is not available on Figma for Government plans
Creating and editing motion requires can edit access to the file.
Create production-ready animations directly in your design files with Figma Motion.
- Animate your designs: Quickly add motion with preset animations, or build your motion from the ground up with keyframes.
- Fine-tune your motion: Use easing curves and spring animations to shape how your motion feels.
- Generate a first pass with the Figma agent: Describe the motion you want and let Figma agent add keyframes to the timeline. Then refine the details manually or keep prompting until the motion is just right.
- Build your motion system: Maintain consistency across your motion system with timing and easing variables and animated components.
- Ship your animations: Use the read-only timeline in Dev Mode to inspect animations at full fidelity, then copy code into CSS, JSON, or React. Or send animation context to your coding tools via the Figma MCP server.
Learn more about Figma Motion.
New to motion design? Check out the Motion design fundamentals collection to learn the principles behind effective motion design and gain hands-on practice creating animations.
Frequently asked questions
When will I get access to Figma Motion?
Figma Motion is rolling out gradually on June 24, 2026. If you don't see it in your account yet, check back soon!
Who can access Figma Motion?
Figma Motion is available on all plans in Open beta. You can access Figma Motion in any design file you have can edit access to by switching the toolbar toggle to Motion.
Publishing animated components, generating animations with the Figma agent, and high-resolution video exports require a Full seat on a paid plan.
Figma Motion is not available on Figma for Government plans.
Does Figma Motion consume AI credits?
Figma Motion doesn't use AI credits directly, but using the Figma agent to create motion will use AI credits in the future. Currently, while the Figma agent is in beta, it does not use AI credits. Once the agent is generally available, standard AI credit usage will apply. Manually editing agent-created motion never consumes credits.
Organization admins can download a CSV to view usage data for Figma agent in Figma Design—as well as some other AI features in beta—in order to understand trends ahead of the feature moving into general availability. Learn how to view credit usage for AI features in beta.
What export formats does Motion support? Do you plan on supporting more in the future?
Export Figma Motion files as MP4, GIF, WEBM, or Animated SVG. We will introduce additional formats in the future, including Lottie.
Weave tools in Figma Design Open beta
Before you start
Available on Professional, Organization, and Enterprise plans
Using a Weave tool requires can edit access to a file
Learn more about Figma Weave
Plug inputs into the straightforward UI of Weave tools in Figma Design and generate quality assets on repeat – without the need for robust prompting. Weave tools make it easy to quickly execute on common AI image tasks, like replacing a background, adding a logo to a product, and changing the aspect ratio of an image.
- Choose from a curated list of Weave tools in Figma Design to accomplish simple AI image generation task
- Weave tools are backed by powerful AI workflows, saving you from having to write new prompts yourself
- Swap out inputs and receive consistent results every time you run a Weave tool
Learn more about using Weave tools in Figma Design.
Does Weave tools consume AI credits?
Weave tools in Figma are in open beta. They are free to use during the beta, so AI credits are not consumed for any prompts or actions. This allows you to explore and experiment without worrying about credit usage. Once Weave tools in Figma become generally available, AI credit usage will apply.
Organization admins can download a CSV to view usage data for Weave tools—as well as some other AI features in beta—in order to understand trends ahead of the feature moving into general availability. Learn how to view credit usage for AI features in beta.
Agent in Figma DesignOpen beta
The agent in Figma Design helps you explore, edit, and refine designs through natural conversation.
Use the agent to:
- Generate and remix designs using your design system components, styles, and variables
- Automate bulk edits—update copy, swap content, apply variables, and restructure layouts across multiple frames at once
- Get design feedback, including accessibility reviews and critiques from different user personas
- Ask how-to questions about Figma—the agent draws from the Help Center for accurate answers
- Run multiple prompts in parallel without waiting for each to finish
Learn more about Figma's agent.
Does Figma agent consume AI credits?
The agent is free to use during the beta. AI credits are not consumed for any prompts or actions. This allows you to explore and experiment without worrying about credit usage.
Organization admins can download a CSV to view usage data for the agent in Figma Design—as well as some other AI features in beta—in order to understand trends ahead of the feature moving into general availability.. Learn how to view credit usage for AI features in beta.
Custom shader effects and fillsOpen beta
Before you start
Creating custom shaders with the Figma agent is available in Figma Design on all plans.
Using a custom shader requires can edit access to the file
Figma-created shader effects and fills are available on all plans
Prompt to build custom shader effects and fills you can save and reuse to create striking visuals, add personality to your designs, and help your brand stand out.
- Native creation tools: Create shader effects directly in Figma Design with prompts
- On canvas controls: Shaders use Figma’s UI so they feel like native properties
- Natively rendered: WebGPU shaders as custom effects, making it possible to build new fills
- Use across Figma: Export effects to Figma Make and other platforms via MCP
Learn how to build custom effects and fills.
Do I have access to custom shaders?
Anyone with access to the Figma agent can generate shaders in Figma Design while the feature is in open beta.
Using custom shaders requires edit access to the file.
Do I need to know how to code to create shaders?
No. Shaders can be prompted through chatting with the Figma design agent. You describe what you want and the design agent generates the shader for you.
Do shaders consume AI credits?
As of now, shaders do not consume AI credits. Once the Figma agent becomes generally available, standard AI credit usage will apply to build shaders with the agent. It does not consume AI credits to apply shaders.
Organization admins can download a CSV to view usage data for the agent in Figma Design—as well as some other AI features in beta—in order to understand trends ahead of the feature moving into general availability. Learn how to view credit usage for AI features in beta.
Can I use shader effects in other Figma products?
Yes. Shader effects support export to Figma Make and other platforms via MCP.
- PNG will always work for a fixed frame
- MP4 export will work in Motion with Shaders
- MCP (crude/raw) code export will be supported
- This means that devs will have access to the JS/WGSL
Shader effects do not currently appear in Dev Mode, but this is something our product teams are actively exploring.
Generative pluginsOpen beta
Before you start
Creating generative plugins with the Figma agent is available in Figma Design on all plans.
Using generative plugins requires can edit access to the file
Figma-created plugins are available on all plans
Prompt the Figma agent to build reusable plugins right in your file that feel native to Figma. Create custom tools that support your unique workflow, like reordering or sorting layers by criteria, applying consistent spacing or padding across selections, or finding and replacing text or colors across a file.
- Prompt-to-create: Build custom plugins by chatting with the Figma agent
- On canvas controls: Plugins use Figma’s UI so they feel like native tools
Learn more about generative plugins.
When will I have access to generative plugins?
The ability to create generative plugins are rolling out gradually on June 24, 2026. If you don't see one of the new features in your account yet, check back soon!
Can I still build plugins without the agent?
Yes — the agent introduces an additional path to building plugins. Classic plugins aren’t going anywhere and we’re continuing to invest in resources for developer plugins. Additionally, we’re investing more in new plugin APIs and new plugin UI; these investments will be available to both generative plugins and classic plugins.
Who can access the plugins I build with the agent? Can I publish one to the Community?
At launch, generative plugins live in your file and are accessible to anyone with access to that file. The plugins you create are also available across all your own design files. We plan to bring public publishing to Community and private publishing to your organization in the coming months.
Where do generative plugins run? Who hosts them?
Generative plugins are hosted by Figma. They are written and run right inside your Figma file. Classic plugins are built on your local machine using the Figma desktop app and a development environment like Visual Studio Code or Cursor, and then published to the Figma Community where other Figma users can discover and run them.
Do generative plugins consume AI credits?
As of now, generative plugins do not consume AI credits. Once the Figma agent becomes generally available, standard AI credit usage will apply to build plugins with the agent. It does not consume AI credits to run an generative plugin.
Write to canvas Open beta
Before you start
Write to canvas is in Open beta.
Write to canvas is available to Full and Dev seats on paid plans.
Dev seats only have read-only access outside of drafts.
Write to canvas lets AI agents create and modify content directly in your Figma files using the use_figma tool in Figma’s MCP server.
With use_figma, agents can write real, editable content to the canvas instead of a rough approximation. Depending on the workflow and skill being used, this can include creating and updating content in Figma Design files or working with FigJam boards.
You can use Write to canvas to:
- create and update content in Figma Design files
- work with FigJam boards through supported FigJam skills
- build with your team’s existing components, variables, layout structure, or board content
- turn prompts into real, editable canvas content
Learn more about write to canvas.
Write to canvas FAQ
Write to canvas can support both Figma Design and FigJam workflows, depending on the tool and skill combination being used.
Figma Buzz Open beta
Before you start
Figma Buzz is in Open beta.
While in beta, Figma Buzz is available on all seats and plans.
Figma Buzz enables brand designers to build workflows for marketers to create campaigns confidently and move at the pace of their ideas—all within Figma. Use Figma Buzz to make assets such as social media posts, digital ads, event materials, and more.
- Publish templates: Copy and paste from Figma Design to Figma Buzz, make necessary tweaks in design mode, and publish in buzz for your peers to easily access and use.
- Controlled editing: Teams can edit select sections within published templates, ensuring they are always staying on brand.
- Freeform editing: Select a template, start from scratch, or use a custom size to create exactly what you need. Riff and refine with design tools in a simplified editor.
- Creation at scale: Quickly create and edit thousands of assets at once. See them all in one view, regardless of size.
Figma Buzz FAQ
Figma Buzz is available on Education plan accounts.
Figma Buzz is not available on Figma for Government.
Yes, AI features are available in Figma Buzz.
See a list of AI features available in Figma Buzz.
As an admin, you can choose to disable access to AI features for your team or organization.
Figma Sites Open beta
Before you start
Figma Sites is in Open beta.
Figma Sites is available on all plans. Publishing a site to a live domain requires a paid plan.
Requires a Full seat to edit and publish sites. Users with Dev, Collab, or View seats can view site files.
Figma Sites is an all-in-one tool for designing, prototyping, and publishing websites. In Figma Sites, you can:
- Copy from Figma: Copy and paste your Figma designs into Figma Sites for easy migration.
- Templates: Get started with pre-designed website templates.
- Assets & blocks: Pull in your design system and premade web elements.
- Breakpoints: Layouts, text, and components can adapt for different screen sizes.
- Interactions: Apply interactions like marquee, scroll parallax, and much more with a few clicks.
- Preview & publish: See live HTML preview in canvas and publish designs straight to the web.
Figma Sites FAQ
In Figma, a user’s seat type determines which Figma products and functionalities they can access.
- In Figma Sites, a Full seat is required to edit and publish site files.
- Users with Dev, Collab, or View seats can view site files.
During the beta, we're gradually enabling publishing capabilities.
Here's what you can expect:
- Publishing is being rolled out gradually to users. You may be able to create and edit sites before you can publish them.
- If you attempt to publish and see a disabled state or a tooltip message, your account hasn't yet been enabled.
- We'll notify you directly in-product once publishing is activated for your account.
If you currently can't publish your site, it may not have rolled out to your account yet. Or, if you’re on the Organization or Enterprise plan, your admin may have turned off publishing capabilities for your organization. Learn more about managing site publishing for an organization.
By default, anyone with a Full seat can publish a site to the web using Figma Sites. On the Organization and Enterprise plans, organization admins have the ability to disable site publishing to align with their company’s information security practices.
Learn more about managing web publishing for an organization.
There are no limits on published websites.
Yes, Figma Sites supports custom site domains. Organization and Enterprise plans can set up unlimited custom domains, and Professional plans can set up 10 custom domains free of charge through 2025.
Figma Sites is not currently available for Figma for Government accounts.
Figma Sites is available for Figma for Education accounts.
While in beta, Figma Sites is available to all paid plans. Go to figma.com/pricing-faq to learn more.
Figma is not responsible for content that is published from Figma Sites. Published sites are accessible to anyone on the public web, and you are responsible for complying with any regulations or laws that apply to your content or any data you collect from visitors to your published sites. If you're unsure about what those obligations are or how to comply with them, please consult a lawyer.
Figma reserves the right to remove any published content that is reported and determined to violate Figma’s Acceptable Use Policy.
Desktop app Open beta
Figma has a beta version of the desktop app available.
By using the beta version of the app, you're helping Figma test bug fixes and performance improvements, before we release them to the general public. The beta version does not give you access to features Figma hasn't released yet.
You can install and use the Figma desktop app and the beta version at the same time. Both versions of the desktop app will offer the same core features and functionality.
Learn how to download the beta version of the desktop app.
Agent in FigJam and Figma Slides Closed beta
Before you start
Available on paid plans
Requires can edit access to the file
The agent in FigJam and Figma Slides helps your team ideate, present, and align on what to build, when you’re building faster than ever.
Use the agent to:
- Use FigJam to capture team inputs and then ask the agent to turn the board into slides for a product review to get quick approvals
- Leverage the agent to help visualize complex systems and architecture in a way that is more easily understood by the rest of the team
- Turn a brainstorm in FigJam into actionable next steps. Use connectors to get these next steps captured as tickets in your preferred task management software
The agent in FigJam and Figma Slides is rolling out gradually to accepted participants. Join the waitlist to apply for access.
Figma Make in your local codebase Closed beta
Before you start
Requires the Figma Beta desktop app for Mac
Requires a codebase hosted in a Git repository
Figma Make in your local codebase lets you connect a Git repository and edit the running app directly inside Make. Your app opens with real data, and you can change the UI by adjusting properties in a panel, annotating elements, or describing changes in chat. The agent updates the code, and when you're ready, you can create a branch and open a pull request without leaving Figma.
Use Make in your local codebase to:
- Open a local repository or clone one from GitHub and see your live app with real data
- Adjust layouts, colors, fonts, and spacing on selected elements with the editing panel
- Annotate specific elements to describe changes in context, and stack annotations to queue several changes at once
- Chat with the agent to describe code changes in plain language
- Create branches, make local commits, and open pull requests for your engineering team to review
Make in your local codebase is rolling out gradually to accepted participants.
Sign up to get early access to our other features in closed betaEarly access sign-up
You can apply for early access to these tools with one request using this form.
- Code layers: Design with code on the Figma canvas
- 3D transforms in Figma Design: We are bringing native 3D transforms to Figma, from editable spatial design to dev-ready export.
Waitlist frequently asked questions
How do I join the waitlist?
You can join the waitlist using this form.
After submitting the form, you’ll receive an automated confirmation email letting you know that your request was received. While joining the waitlist doesn’t guarantee immediate or early access, it helps our team understand your interest in the feature(s).
How can I tell if I’m on the waitlist?
Once you’ve added your name to the waitlist, you’ll receive an email confirmation that verifies you are on the waitlist. If you aren’t sure whether you have signed up yet, check your email for the confirmation.
This doesn’t guarantee early access but will let our team know that you’re interested.
Can I request my whole team or organization get access?
Access is evaluated on a feature-by-feature basis. Depending on the feature and its rollout plan, access may be granted to an individual, a team, or an entire organization. If you're selected for a beta, we'll communicate the scope of access as part of the onboarding process.
