Who can use this feature
Starter, Professional, Education, Organization, and Enterprise plans
Figma Motion is currently in open beta. Features may change and you may experience performance issues as we continue to improve Figma Motion. Learn more about what's included in the beta.
When you apply position keyframes to an object, the movement is displayed as a motion path on the canvas. A motion path appears as a sequence of dots indicating an animation's easing and boxes marking the position of each keyframe.
Edit a motion path
You can edit the motion path to change how an object moves. An object’s motion path can only be edited in Figma Motion.
- Select an object with position keyframes applied to reveal its motion path.
- Do one of the following:
- To reposition a keyframe: Click and drag it to a new position on the canvas
- To curve a motion path: Hold Command (Mac) or Control (Windows), then select a keyframe and use the handle to change the path’s curve
Note: An animation’s easing also influences how an object moves. To adjust an animation’s easing, select the animation on the timeline or click the line between two keyframes, then choose an option from the Easing menu. Learn more about easing.
Getting started with animation? Visit the Motion design fundamentals collection to learn the principles behind effective motion design and get hands-on practice creating animations in Figma Motion.
For more interactive learning experiences, check out the Figma Motion playground file on the Figma Community.
