Work with the Figma agent in FigJam boards
Before you start
Who can use this feature
- Professional, Organization, and Enterprise plans
- Anyone with access to the board can chat with the agent about its contents
- Requires edit access when asking the agent to make changes
Use the Figma agent in FigJam to generate boards and diagrams, organize or summarize board content, and turn ideas into next steps with your team.
Start with a prompt or select content on your board, then ask the agent to help you develop it. Review the results with your team and ask for changes as your ideas take shape.
You can open the agent in either of these ways:
Click the Agents chat at the bottom left of the board.
Select one or more objects on the board and click Ask agent.
Tip
To turn off the Ask agent option in the toolbar, click Main menu > Preferences > Show Agents on canvas.
Work with the agent in FigJam boards
The agent can help you create, understand, or make changes to your board. Review the agent’s work as you go, then follow up with questions or requests to refine the results.
You can start multiple threads simultaneously with the agent without waiting for each one to finish.
Add context to your prompts
Give the agent context by attaching existing designs, images, and other files, or by adding skills.
Use Connectors to bring in information from external apps. Choose from more than 20 verified partner connectors or create your own.
Navigate your chats
With chat open, click in the chat sidebar to see all your chats in one place. The sidebar lists chats from most to least recent, with a preview of each chat’s last message.
From here you can search, make chats private, or rename them.
Undo changes
Click Undo in the chat to revert the most recent change. To compare versions side by side, first duplicate the content updated by the agent, then undo changes to the original.
Ways to use the agent
Use the agent to prepare a session, explore an idea, or make sense of work already on your board. Try one of the prompts below, then ask for changes to refine the results.
Turn workshop notes into clear next steps
Turn your team’s stickies and comments into an editable document that captures decisions, next steps, and open questions.
“Summarize this discussion as a spec. Include decisions, next steps, and open questions.”
Create a journey map from research and data
Combine research findings and quantitative data to explore where users struggle or drop off. Attach your sources or provide context through connected apps.
“Create a journey map from these sources. Show stages, pain points, drop-off evidence, and open questions.”
Set up a brainstorming session from a prompt
Create a starting point for a team brainstorm without building the board from scratch. Describe the topic, participants, and desired outcome.
“Create a brainstorming board 5 people with 2 rounds of ideation. Our goal is to improve new-user onboarding. Include an introduction, idea prompts, and space to discuss next steps.”
Sketch a flow to explore an idea
Turn a written process into a flowchart to spot missing steps and decision points.
“Create a flowchart for new-user signup, including email verification and an invalid-email path.”
Supported features
Here’s an overview of what the agent can help you do in FigJam.
| Feature | Currently supported | Examples and limitations |
| Generate boards and diagrams | ✓ | Start a brainstorming board or turn a process into a flowchart. |
| Organize and summarize board content | ✓ | Group ideas, summarize discussions, and identify decisions and next steps. |
| Use MCP connectors | ✓ | Connect apps to bring information into your board or send updates back to those apps. |
| Use skills | ✓ | Save your team’s workflows and preferences as reusable instructions for the agent. |
| Search the web | ✓ | Find information online, look up documentation, and get answers to factual questions. |
| Attach files to prompts | ✓ | Give the agent context by attaching Figma files, images, text files, PDFs, and more. Audio and video attachments aren’t supported in FigJam. |
| Create and refine spec files | ✓ | Turn board content into an editable document and refine it with your team. |
| Create and edit sticky notes | ✓ | Add ideas or rewrite sticky notes. When the agent creates or edits a sticky note, the note doesn’t show the agent as its author. |
| Create sections | ✓ | Group related objects into named sections to organize ideas, separate activities, or make your board easier to navigate. |
| Add text to the board | ✓ | Add headings, instructions, or labels to organize your board and guide participants. |
| Create and edit tables | ✓ | Compare options or organize action items with owners and due dates. The agent can create, edit, and delete tables, but it can’t merge or split cells. |
| Add shapes to the board | ✓ | Add shapes to represent steps in a process, highlight decisions, or label areas of the board. |
| Select objects on the board | ✓ | Find and select objects, then change, group, or move them. |
| Export board content | ✓ | Export all or part of your board as a PDF or image. |
| Review comments | ✓ | Summarize, sort, and act on comments in your file. |
| Provide feedback | ✓ | Get feedback on ideas or brainstorms. Ask the agent to consider different perspectives, such as a new user or a VP of Product. |
| Create and edit images | ✓ | Create images, remove backgrounds, or ask for changes to an existing image. |
| Figma file actions | ✓ | Add comments, create pages, and update file details. |
| Search Figma files | ✓ | Find other files and bring their content into your board without leaving it. |
| Use the marker or highlighter | Limited | The agent can draw shapes that resemble marker or highlighter strokes, but it can’t use those tools. |
| Read widgets | Limited | The agent may miss links or information that isn’t currently visible. |
| Work with face stamps | Limited | The agent can copy existing face stamps, but it can’t tell whose face is shown or create a face stamp from someone’s name. |
| Work with stamps | Limited | The agent can work with stamps and recognize patterns in how someone has used them, but it can’t tell you who added them. |
| Create charts and data visualizations | Limited | Ask the agent to turn data into a chart or another visual. However, results may vary, so review them carefully. |
| Insert code blocks | Limited | Add code to your board. You may need to interact with the code block before its color formatting appears. |
| Generate and edit design elements | Limited | Create some complex shapes and vector artwork. Editing is limited: the agent can’t select objects inside design frames or change existing vector artwork in FigJam. |
| Use custom fonts | Limited | The agent tries to keep the fonts you’ve chosen. If it can’t access a custom font, it may ask you to make that font available. |
| Format bulleted lists | Limited | Bullet points may not appear correctly in sticky notes, shapes with text, or tables. |
| Copy chat responses to the canvas | Limited | You can copy a response onto your board, but links shown as chips in the chat won’t carry over. |
| Create washi tape | Not supported | |
| Create and edit widgets | Not supported | |
| Create embeds | Not supported | |
| Browse and use templates | Not supported | |
| Send a board to Figma Design, Figma Slides, or Figma Make | Not supported | |
| Boost image resolution | Not supported | |
| Start or stop music, timers, or voting | Not supported | |
| See who’s active in the file, their cursors, or their selections | Not supported | |
| Use the agent in the Zoom integration | Not supported |
Frequently asked questions
How many AI credits does it cost to use this feature?
The number of credits used by the agent changes based on the complexity of the task. Learn more about how AI credits work.
What’s the difference between the Figma agent and using MCP in Claude or Codex?
The agent in FigJam lets you work directly in your boards, side-by-side with the agent, helping you and your team explore, refine, and build without switching context.
Can I use the agent on mobile?
The agent is currently only available from the desktop app or web browser.
Can I use the agent in other Figma products?
The Figma agent is also available in Figma Design, Figma Make, Figma Specs, and Figma Slides.
