Work with the Figma agent in slide decks
Before you start
Who can use this feature
- Professional, Organization, and Enterprise plans
- Anyone with access to the presentation can chat with the agent about its contents
- Requires edit access when asking the agent to make changes
Use the agent in Figma Slides to turn ideas and source material into presentations, review and refine outlines, and make changes to slides with your team.
You can get started with the agent in any of these ways:
In a new Slides file, describe what you want to present. Include your audience, purpose, key points, and approximate slide count, then send your prompt.
Open Agents in the left sidebar to work with the agent on any part of the slide deck, including adding or improving content or speaker notes.
Make targeted edits by selecting one or more design layers on a slide and clicking Ask agent.
Work with the agent in Slides
Start with a prompt or an existing presentation, then ask the agent to help you develop it. Review the outline before generating a deck, and follow up with requests to refine the results.
You can start multiple chats with the agent at the same time, without waiting for each one to finish.
Add context to your prompts
Use Add context to bring in images, Figma files, and other files or sources. You can also include a public URL in your prompt. Specify your audience and desired outcome, and check source details before presenting.
Review and refine the outline
When you ask the agent to generate a deck, it creates an outline for you to review. Edit the outline directly, or choose Refine outline to request changes. Click Generate deck when you’re ready.
Navigate your chats
Click Agents in the left navigation bar to open the chat sidebar and see all your chats in the file. Chats are sorted by recency, with a preview of the last message in each chat.
- Click New chat at the top of the chat window to start a new conversation.
- From within a conversation, click Back to see all your chats in the file.
Undo changes
Click Undo in the chat to revert the most recent change. To compare versions side by side, duplicate the content the agent updated, then undo the changes to the original.
Ways to use the agent
Find the story in your source material
Bring in a document or external data and ask the agent to identify the key findings, shape a narrative, and turn it into a first draft for your audience.
“Use this project report and the attached data to create a six-slide team update. Find the main story, highlight the findings that support it, and end with open questions and next steps. Let me review the outline first.”
Give a project a visual starting point
Turn a short brief into a presentation with a shared goal, plan, and next steps. Click Select deck template to search for a template or paste a link to an existing deck to guide the presentation’s style.
“Using the selected template, create four concise slides for a volunteer trail-cleanup kickoff: purpose, goals, schedule, and next steps. Use only the facts in this brief.”
Adapt a deck for a different audience
Get an existing presentation ready for a new audience. Ask the agent to sharpen the takeaways, simplify the language, and move supporting detail into presenter notes.
“Adapt this project update for an executive review. Focus the slide copy on outcomes, risks, and decisions needed. Move supporting detail into presenter notes, and preserve the facts and visual style.”
Supported features
| Feature | Currently supported | Examples and limitations |
| Generate a presentation | ✓ | Build a deck from a prompt, source material, or a supplied outline. Review the result before presenting. |
| Review and edit outlines | ✓ | Edit headings, supporting text, and presenter notes before generation; ask the agent to add or refine slides. |
| Add presenter notes | ✓ | Include notes in the outline and carry them into the generated presentation. |
| Refine existing slides | ✓ | Rewrite copy, adjust layouts, or make a focused change to selected content. |
| Make bulk edits | ✓ | Ask for changes across a presentation, such as shortening copy or making terminology consistent. Review the affected slides. |
| Summarize a presentation | ✓ | Ask for the main points or a summary tailored to your audience. |
| Add slides to an existing deck | ✓ | Ask for a new slide while keeping the rest of the presentation. |
| Duplicate and reorder slides | ✓ | Duplicate a slide and move the copy to a different place in the presentation. |
| Change colors and sizing | ✓ | Update selected shapes or several objects in a slide. For charts built from shapes, check that edited values and proportions still agree. |
| Add text and headings | ✓ | Create editable titles, labels, or other text on a slide. |
| Create shapes and connectors | ✓ | Add shapes and connect them to explain a process. Review the layout and connections. |
| Format text | ✓ | Change text properties such as the font. For example, display a code snippet in a monospace font; this does not create a native code block. |
| Get presentation feedback | ✓ | Ask for a critique of your slides, such as ways to make a process clearer or improve the story for your audience. |
| Use MCP connectors | ✓ | Bring documents and data from connected apps into your work. Available actions depend on the connector and its permissions. |
| Use skills | ✓ | Save repeatable workflows and preferences as reusable instructions for the agent. |
| Search the web | ✓ | Find information online to inform a presentation. Check the sources and resulting claims before presenting. |
| Attach files to prompts | ✓ | Add Figma files, images, documents, PDFs, and data as context. Audio and video attachments aren’t supported in Slides. |
| Fetch a public source URL | ✓ | Build from a linked public page. Some sites may block access. |
| Search Figma files | ✓ | Find other files and bring their content into your slide deck without leaving it. |
| Use a template or reference deck | Limited | Guide the deck’s visual style with a template or a deck you can access. The result may differ from the reference, so review the layout and styling. |
| Generate diagrams | Limited | Build simple diagrams from editable shapes, text, and connectors. Review the result carefully, especially for more complex diagrams. |
| Create charts and data visualizations | Limited | Illustrate supplied data using editable shapes and text. Check values, proportions, and labels; do not assume the result is a native or data-linked chart. |
| Attach audio or video to a prompt | Not supported |
Frequently asked questions
How many AI credits does it cost?
The number of credits used by the agent depends on the complexity of the task. Learn more about how AI credits work.
What’s the difference between the Figma agent in Slides and using MCP in Claude or Codex?
The agent in Slides lets you work directly in a presentation with your team. You can develop an outline, generate slides, and refine the deck in the same file. The Figma MCP server lets you work with Figma from an external AI tool such as Claude or Codex.
Can I use the agent in other Figma products?
The Figma agent is also available in Figma Design, Figma Make, FigJam, and Figma Specs.
Will the generated deck exactly match my template?
The agent uses your template or reference deck to guide its style, but the result may differ. Review the generated slides and refine the layout, styling, and content before presenting.
