Who can use this feature
Has someone shared a file or prototype with you and you no longer want access to it? You can leave the file to remove it from your account.
- You can only leave files you have explicit access to. If you have inherited access to the file via a folder or team, you need to leave that folder or team to remove your access.
- If you're the owner of the file, you need to transfer ownership of the file before you can leave it.
Leave a file
To leave a file:
- Access the share modal in one of two ways:
- Find the file in the file browser, then right-click on the file and select Share.
- From an open file, click Share in the top right.
- Find your name in the list of collaborators.
- Click on your current access level and select Leave from the options.
Leave a prototype
To leave a prototype:
- From the prototype, click Share prototype in the top right.
