Who can use this feature
If you no longer need to be a part of a team, you can leave it. When you leave a team, you will no longer have access to any files, folders, or libraries in that team.
If you want access to the team again in the future, an existing member can always invite you to re-join.
Caution: If you're the last member of the team, Figma will delete the team and any files and folders when you leave it. The team owner or a team admin has 28 days to restore the team once it's delete. Restore a deleted team →
Transfer ownership
If you're the owner of a team and wanting to leave the team, we recommend transferring ownership of the team before you do.
If you are the owner of any team files or folders, Figma will transfer ownership of those folders or files to the current owner of the team when you leave.
On the Professional plan, if the team is paid for using your credit card or billing details, Figma won't remove your billing details when you leave. Make sure to update the billing details for the team to a company card, or another team member's card.
Leave the team
To leave a team:
- Open the file browser by logging in to your account at figma.com. If you’re in a Figma file, click the Figma menu > Back to files.
- Navigate to the team:
- On the Starter or Professional plan, select All folders from the left sidebar.
- On the Organization or Enterprise plan without workspaces enabled, select All teams from the left sidebar. Then, select a team.
- On the Enterprise plan with workspaces enabled, select All workspaces from the left sidebar. Then, select a team from the Your teams tab.
- Next to the team name, click Open team dropdown.
- Select View members.
- From the member list, find your name and open the dropdown next to it.
- Click Leave.
