- Anyone with can edit access to a FigJam file can use stamps.
- Anyone with can view or can edit access to a FigJam file can use emotes.
Stamps can be placed in a file for visual feedback. These are great for both live and async collaboration.
Emotes are temporary and great for live, energetic reactions with others who are active in a file.
Stamps
Stamps are emoji stickers you can place on a board or object to communicate feedback.
Use stamps to:
- Generate heat maps
- Vote between several ideas
- Assign people to tasks
- Gather asynchronous input
Note: It's not possible to customize the stamp wheel with your own stamp designs. Instead, use sticker packs from libraries for more options, or use them as inspiration to make and publish your own from Figma Design.
How to use stamps:
- Open the stamp picker:
- Click Stamp in the toolbar, or
- Press E on your keyboard
- Select a stamp. To view more emoji options, select the plus icon in the center of the stamp wheel, or press E.
- Click on the board or on an object to place the stamp.
The center of the stamp wheel displays a combination of recently and frequently used stamps. To exit out of the stamp tool, press esc or click elsewhere on the board.
Stamps attach to objects when you place them on top of items like sticky notes or images. Attached stamps move with the object when it’s repositioned.
Tip: Hover your cursor over a stamp on the board to see who added it.
Team face stamps
If you're part of a Figma organization, use team face stamps to attribute and assign objects on your board to collaborators. Team face stamps can be added to a board in a couple ways:
Toolbar:
- Click the plus icon in the toolbar.
- Click the More tab > Faces.
- Search for a collaborator or select a face from the suggestions.
- Click or drag the face to your board.
Stamp wheel:
- Click Stamp in the bottom toolbar or press E.
- Add your face stamp to the board.
- Select the stamp and click the down arrow.
Resize stamps
Change the size of your stamp while placing it down or after it's been placed.
Hold and wiggle
Increase the size of your stamp while placing it down.
- Open the stamp wheel and choose your stamp.
- Click and hold. The stamp will wiggle and grow.
- Release once you've reached the desired stamp size. Stamps will be fully grown after four stages.
Adjust bounding box
Change the size of a stamp after it's been placed via its bounding box.
- Click on a stamp that's already been placed. A bounding box with handles will appear.
- Click and hold one of the handles, then drag your cursor to resize.
Learn more about resizing objects in Figma.
Emotes
Emotes are bursts of temporary emoji reactions used to:
- Give support to someone presenting their ideas.
- Provide lightweight feedback while collaborating.
- Greet and capture attention of others in a file.
How to use emotes:
- Hold shift and click anywhere on the board to release a burst of emotes.
High fives
High fives are a fun way to celebrate achievements, greet others, or capture someone's attention in a file.
How to use high fives:
- Enter high five mode in one of two ways:
- Shake your cursor left and right
- Hold
H. Letting go will exit high-five mode.
- Once in high-five mode, a hand will appear above your cursor. From here, bump your cursor against another collaborator's high five cursor to start high-fiving!
- When you're done, exit high-five mode in the following ways:
- Let go of
Hkey. - Press
Esc - Click anywhere in your file
- Use another keyboard shortcut
- Open a menu
- Let go of
Figma will also eventually fade your high five hand and switch back to the select tool if you've been idle for a while.
To disable entering high five mode when shaking your cursor, click in the top-left corner, go to Preferences, and uncheck Shake cursor for high five.
