Error 403 is a web server error that’s generally related to permissions. In Figma, this more commonly happens in the desktop app, and can have a few root causes:
Common causes and solutions
You have been signed out of Figma
The most common cause of a 403 error is that you have been signed out of your Figma account.
How do I check if this is my issue?
Visit figma.com/login and make sure you're signed in to your account.
How do I fix it?
Visit figma.com/login and log in to your Figma account. If you’re already logged in, try the next steps.
You’re accessing Figma using a VPN, firewall, or proxy
If you're using the desktop app behind a firewall, proxy, or Virtual Private Network (VPN), you will see the error message: Connection Error (407).
Contact your IT department or systems administrator to see if this applies to you, or try using a different network.
How do I fix it?
You have two options:
- Use Figma in the browser. You can access the Figma web app from any of our supported browsers. What browsers does Figma support?
- Ask your IT department or systems administrator to unblock Port 443. This is the standard port for websites that are run over SSL (Secure Sockets Layer).
Network settings may be blocking the connection
Try a different network, like another wifi connection or mobile hotspot. If you’re trying to use the Figma desktop app on a work-managed computer, ask your IT department if any network settings are blocking Port 443.
How do I fix it?
There’s an issue with cached permissions
Cached permissions on your device can sometimes prevent you from accessing files you previously did not have access to, but have since been given permission to edit.
Does the issue occur across all browsers, as well as the desktop app? If this only occurs in one place, there is an issue with the cached permissions.
How do I fix it?
Clear the cache for the Figma desktop app or browser. Once cleared, log out and back in to Figma.
Your access to the file has been removed
You may encounter an error if your access to a file has been removed.
If you do not own the file, reach out to the file owner to confirm or request access.
How do I fix it?
Reach out to the file owner to request access.
The file may have been deleted
Check deleted files and restore deleted files if needed. If you do not own the file, ask the owner to check if the file has been deleted or if your access has been removed.
How do I fix it?
If a file's original folder still exists, anyone with can edit access can restore a file. This will also restore the file for anyone who had access to it at the time of deletion.
Restoring a file retains the permissions, comments, version history, and library connections of the original file.
To restore a file:
- Locate the file you want to restore on the Deleted tab.
- Right-click on the file and select Restore.
Note: The restore option does not display if you had can view access to a file. If its parent folder gets deleted, then you won't be able to restore the file to its original location. Instead, you can duplicate the file your Drafts.
