To check which plan you’re on, navigate to the file browser. In the sidebar, you should see either:
- All projects
- All teams
- All workspaces
Tip: Admins with control over billing can see their plan from admin settings.
- From the file browser, click Admin in the left sidebar.
- Select the Billing tab.
- Look for mentions of Professional, Organization, or Enterprise. This is your plan.
If your sidebar contains ‘All projects’
If you see All projects in your sidebar, you’re on either the free Starter plan, Education plan, or paid Professional plan. Click on All projects.
A team on the paid Professional plan will have a label next to the team name that says ‘Professional’.
If your team doesn't have this label, scroll all the way to the bottom of the projects page. A team using the Education plan will have a banner at the bottom that says, "This team is for Education users only. New users will be required to verify their Education status."
If your team doesn’t have the above label or banner, you are on the Starter plan.
If your sidebar contains ‘All teams’ or ‘All workspaces’
If you see All teams in your sidebar, you’re on either the Organization or Enterprise plans.
If you see All workspaces in your sidebar, you’re on the Enterprise plan. The Enterprise plan has an additional, optional layer of structure, called workspaces. Workspaces are collections of teams.
Tip: If you’ve joined multiple plans, you can also click the team or organization name in the file browser sidebar to see which plan each team or organization is on.
