Before you start
Who can use this feature
Available on all plans
Anyone with can edit access can use auto layout
This article covers just one aspect of working auto layout. Check out these other articles to learn more about working with auto layout in Figma Design.
- Guide to auto layout: An overview of auto layout, how it works, key properties, and browse a collection of auto layout resources.
- Toggle auto layout on a design: Learn how to add auto layout to frames and layers so that you can start making your designs responsive.
- Use the grid in auto layout flow: Learn how to work with columns, rows, and cells with the grid layout flow.
- Create multi-dimensional auto layout flows: Combine multiple auto layout flows to build fully responsive components and screens.
Vertical and horizontal flows
The Vertical auto layout flow places objects in your frame along the y-axis. Any objects you add, remove, or reorder will follow the y-axis. For example: list items in a to-do list, or posts within a newsfeed or timeline.
The Horizontal auto layout flow objects in your frame along the x-axis. Any objects you add, remove, or reorder will follow the x-axis. For example: a row of buttons, or icons in a mobile navigation menu.
Wrap is available for horizontal and vertical auto-layout flows. Wrap moves child objects to a new row or column when they no longer fit in the frame.
- Horizontal flow: objects fill the frame from left to right and wrap into a new row when they run out of horizontal space.
- Vertical flow: objects fill the frame from top to bottom and wrap into a new column when they run out of vertical space.
Wrap
Use Wrap when you want objects to reflow instead of continuing beyond the available space in an auto-layout frame.
- Select an auto layout frame.
- Choose a <span class="ui-icon icon-ui3-24-al-layout-horizontal"></span> Horizontal or <span class="ui-icon icon-ui3-24-al-layout-vertical"></span> Vertical flow.
- Turn on Wrap.
In a Horizontal flow, objects fill the frame from left to right. When they run out of horizontal space, they continue in a new row.
In a Vertical flow, objects fill the frame from top to bottom. When they reach the height of the frame, they continue in a new column. Use a fixed frame height to control where each new column begins.
Vertical wrap behaves like CSS flexbox with flex-direction: column and flex-wrap: wrap.
Note: Vertical wrap is not a masonry layout. Objects remain in auto-layout order and move to the next column only after the current column reaches the frame’s available height.
Resizing
Resizing allows for objects to adapt their dimensions to the objects and spacing properties around them. You can set resizing behavior on a parent auto layout frame to determine how it resizes based on changes made to its contents, and vice versa.
Note: A frame can no longer be sized smaller than its own padding (plus any inside stroke, if included in layout). If a frame is set to hug contents or a fixed size smaller than its padding, the frame will size up to fit the padding.
Learn more about the resizing property.
Alignment
Choose how to align child objects within an auto layout frame. What alignment options are available are determined by the flow of the auto layout frame and the distribution, or gap between items.
Unlike objects in a regular frame, you can't control the alignment of the objects individually. For that reason, you set the alignment of the child objects on the parent auto layout frame.
Use the alignment box in the right panel to select from nine layout options for the children in a frame.
- Select the box and use arrow keys to switch between the different alignment settings.
- Select the box and press W/A/S/D to set alignment to the edge of the frame.
If gap between items is set to Auto, you have three options for each flow:
- Vertical auto layout flow: Left, Center, Right
- Horizontal auto layout flow: Top, Center, Bottom
If gap between items is set to a specific number, you have the same nine options for each auto layout flow:
- Top left
- Top center
- Top right
- Left
- Center
- Right
- Bottom left
- Bottom center
- Bottom right
When one or more resizing properties are set to hug contents, some selections won't result in visually different layouts on the canvas. This is because hug contents removes any extra space around the child objects.
Note: When a stack with gap set to Auto contains only one child, that object aligns to the left (in a horizontal flow) or top (in a vertical flow) by default. Previously, a single child in an Auto-gap stack was centered by default. You can still change this using the Alignment box in the right sidebar.
Spacing
Use spacing properties, gap and padding, to define how much room there is between objects and around the objects in an auto layout frame.
Gap
Gap determines how objects are distributed in an auto layout frame. If the auto layout frame's flow is set to vertical or horizontal, you'll be able to set the gap between items vertically or horizontally, respectively. If Wrap is turned on for a horizontal or vertical flow, you can set both horizontal and vertical gaps between items. One value controls the gap between objects in the same row or column; the other controls the gap between wrapped rows or columns.
You can set gap in two ways:
To quickly switch between these two settings, click the alignment box and press X.
Use a specified value
Using number values for the gap property allows you to explicitly define how far apart objects are. Enter a value into the field, nudge the values using your arrow keys, or scrub the field using your cursor.
Tip: Hold ⇧ Shift while dragging handles to increase and decrease using your big nudge values.
Use auto spacing
Evenly and Around auto spacing options are currently rolling out to all users. It is possible for you and your collaborators to receive this update at different times.
Setting Gap to Auto will evenly distribute the objects in an auto layout frame, given the available space. To determine they type of distribution you want to use, open the Auto layout settings modal and use the Auto spacing dropdown to choose from the following:
- Between (default): Objects are as far apart from each other as possible with no space allocated at the edges. The gap between objects is equally distributed.
- Evenly: Spacing is distributed equally across gaps and edges. Uses a 1:1 ratio.
- Around: Gaps are twice the size of the edge space. Uses a 2:1 ratio.
The auto spacing options Between, Evenly, and Around match CSS property values space-between, space-evenly, and space-around respectively.
Note: If the objects in the frame are too large to fit with positive spacing, the gap will stop at 0 rather than going negative. Objects in an auto-gap stack will no longer overlap. They'll sit flush against each other instead.
Padding
Padding controls the empty or white space between the boundary of an auto layout frame and the frame’s child objects. You can set padding uniformly, vertically and horizontally, or have different values for top, right, bottom, and left padding.
Adjust the padding using canvas controls or spacing fields in the right panel.
To access canvas controls, select an auto layout frame and hover over it. Pink handles will appear, similar to those in smart selection.
- Click handles to open input fields and enter a numeric value
- Or, click and drag the handle to change the spacing
Tip: Check out our keyboard shortcut guide for shortcuts on setting padding on opposite sides, all sides, and more!
Padding controls in the right panel are separated into vertical (top and bottom) and horizontal (left and right) padding by default.
- To set individual padding, click to use top, right, bottom, and left padding fields.
- To set uniform padding or to use CSS shorthand, hold ⌘ Command or Control and click into any padding field. You can also type CSS shorthand. For example, entering
1,2,3,4sets the top, right, bottom, and left to 1, 2, 3, and 4 respectively. Entering1,2sets the values to top/bottom: 1 and left/right: 2.
Tip: Press the tab key to move between input fields.
Additional auto layout settings
Text baseline alignment
A baseline is the invisible line in which text or a layer sits. In typography, descenders will extend beneath this line.
In some cases, aligning the baselines of layers can create more balance—such as when aligning baselines of text layers with varying font sizes, or when aligning an icon with a text layer.
To align layers by their baselines, select the layers you want to align, and click from the right panel to open auto layout settings. Next to text baseline alignment, click to enable baseline alignment.
Tip: Click the alignment box in the right panel, and press B to toggle text baseline alignment on and off.
Strokes in layout
By default, inside strokes are included and accounted for when calculating the size of objects in auto layout frames, making developer handoff easier.
This may not be ideal during developer handoff, as it doesn't accurately represent how CSS renders borders.
Choose whether strokes will take up space in an auto layout frame by going to the auto layout settings, and using the dropdown next to Inside stroke to select included or excluded from layout.
This setting only affects the frame it's applied to. The Inside strokes setting to incliude or exclude on a parent frame could also affect how a child object's stroke interacted with the parent's layout. Now, each frame's stroke setting is self-contained and a parent's setting no longer changes how a child's stroke is calculated. If you notice spacing changes in nested auto layout frames, check the stroke setting on each frame individually.
Note: Only inside strokes are counted in layout calculations. This includes spacing, fill sizing, and any other frame measurements. Outside and center strokes always paint visually as normal, but they're never factored into layout math, even when a frame's stroke setting is set to included in layout.
Canvas stacking order
When multiple layers have negative spacing creating a stack, the last object (either the right-most or bottom-most object) in the stack will be on top by default.
You can change the visual order of the stack as seen on the canvas.
With the auto layout frame selected, click from the right panel to open auto layout settings. Next to canvas stacking, select:
- First on top: the first layer in the stack will be on top
- Last on top: the last layer in the stack will be on top
Note: When the stacking order changes, the order of layers in the layers panel stays the same. Canvas stacking is solely a visual change that happens on the canvas.
Work with objects in the frame
Add objects
To add a layer or object to an auto layout frame.
- Click and drag an object over an auto layout frame.
- Use the blue indicator to choose where to place the object.
Note: The object's size determines if it can be added to the auto layout frame. If any of the object's dimensions are larger than the parent frame, you won't see the option to add it to the auto layout.
Use the modifier key to bypass Figma's default behavior and add larger objects to an auto layout. Or, to add objects to a nested auto layout:
- Mac: ⌘ Command
- Windows: Ctrl
Duplicate objects
You can duplicate existing objects to add them to the Auto layout. Figma will add the duplicate to the right (horizontal) or below (vertical) the original object.
- Select a child object in an Auto layout frame.
- Duplicate it by using the keyboard shortcut:
- Mac: ⌘ Command D
- Windows: Ctrl D
Arrange or reorder objects
Note: You can't reorder objects in an instance. You will need to change the object's order in the main component, or detach the instance to reorder objects. Learn more about using auto layout in components.
You can change the order that objects appear in an auto layout frame. This is only supported on main components, or auto layout frames outside of a component.
- Select the child object. If the layer is nested, you'll need to use the modifier key to deep select:
- Mac: ⌘ Command
- Windows: Ctrl
- There are a few ways to reorder objects:
- Use the arrow keys on your keyboard the object to a new position.
- Click-and-drag the object to a new position.
Remove objects
To remove an object from a main component or auto layout frame:
- Drag the object outside of the auto layout frame
- Click next to Appearance in the right sidebar, or next to the layer in the left sidebar to toggle the layer visibility
- Select the object and press the Delete or Backspace key
You can't delete a layer or object from an instance. If you try, Figma will only toggle the layer's visibility instead of removing it.
Tip: Toggling a layer or object's visibility will hide it from an auto layout frame. If you want to create a gap in where the object should be, you can adjust the opacity of the object instead. In the right panel, update the Layer settings to 0%.
Try it out
New to auto layout? Play around with the different auto layout properties in the interactive sandbox below to see how they work. Just keep in mind that this demo is a simplified version and doesn’t fully replicate how auto layout works in Figma Design.
What did you think of this demo? Let us know by rating this article at the bottom of the page.
More ways to learn:
Figma tutorial playlist: Learn to create flexible designs and components
This playlist includes video tutorials that cover the basics of auto layout, how to apply auto layout to designs, and hands-on tutorials for more practice. -
Community file: Auto layout playground
Grab a copy of the auto layout playground file to practice while you learn.
