Before you start
Who can use this feature
Figma Slides AI tools are available on paid plans.
Requires a Full, Dev, or Collab seat to use AI tools in Figma Slides.
AI outputs may be misleading or wrong. The information provided by the tools should be regarded as a general reference and not a fact or a substitute for expert advice or your own research.
Learn more about accuracy and responsibilities when using Figma AI.
AI tools let you leverage the knowledge of large language models to help speed up your work in Figma Slides. In this article, you can explore all the AI features available in Figma Slides.
Tip: You can also use AI tools in other Figma products.
Learn more about Figma AI and see a breakdown of AI features available by product.
Available AI tools in Figma Slides
Generate a slide deck
Generate a slide deck from a FigJam board, giving you a good starting point that you can use to build the rest of your presentation.
Learn more about generating slide decks.
Draft presenter notes
Draft presenter notes for any slide with written content.
Learn more about drafting presenter notes with AI.
Rewrite, translate, or shorten text
Rewrite text to give it a different tone, translate it to another language, or shorten it to fit your designs.
Learn more about updating text with AI.
Adjust tone
Use AI to adjust the tone of any text. Quickly rephrase, condense, or expand content to reduce manual rewriting and keep your tone consistent.
Learn more about adjusting tone with AI.
Make and edit images
Generate and edit unique images using a written prompt.
Learn more about making an image with AI.
Remove background
Remove an image’s background to isolate the main subject.
Learn more about removing an image background with AI.
Boost resolution
Improve sharpness and clarity of low-resolution images.
Learn more about boosting resolution with AI.
Search with AI
Figma AI can help you track down slide decks from across your team, organization or within Figma Community files.
Learn more about using AI search.
Troubleshooting
Something not working as expected? Check out our guide to Troubleshooting AI tools.
AI considerations and best practices
There are a few things to keep in mind when using any AI tool:
Accuracy
AI-powered tools are designed to provide information and results based on artificial intelligence algorithms and data collected from around the internet. It’s important to note that the accuracy and reliability of these results may vary.
There is a possibility of inaccuracies, omissions, or misleading outcomes due to the complexities and limitations of AI technologies. Therefore, the information provided by the tool should be regarded as a general reference and not a fact or a substitute for expert advice or your own research.
Your responsibilities
- You should exercise your own judgment and discretion when using AI-powered tools. It’s essential to verify and cross-check the information provided by the tool before making any decisions, taking actions, or relying on it for critical matters.
- You should let others know when you’re using or presenting AI-generated outputs.
- You will only use AI features in accordance with Figma’s Acceptable Use Policy.
