Folders help you organize your files. You can color-code them, control who can access their contents, and on paid plans, nest them up to ten levels deep.
On the Professional, Organization, or Enterprise plan, you can create unlimited folders.
On the Starter plan, you can only have one folder. This means you need to delete a folder before you can create another one.
Create a folder
To create a new folder:
- Open the file browser by logging in to your account at figma.com. If you’re in a specific Figma file, click the Figma menu > Back to files.
- Open a team or plan page.
- On the Starter or Professional plan, select All folders from the left sidebar.
- On the Organization or Enterprise plan, select All teams from the left sidebar and select a team.
- On the Enterprise plan with workspaces enabled, select All workspaces from the left sidebar. Then, select a team from the Your teams tab.
- Decide where to create the folder.
- To create a top-level folder, click + Folder.
- To create a nested folder, click into a folder. Then, select + Create > Folder.
- Enter a name for the folder and click the folder icon to change the icon color.
- Select an option from the Who has access dropdown to determine who from your organization, workspace, or plan can access the folder. (Learn more about folder permissions.)
- Click Continue.
- [Optional] Enter in the email addresses of any users or user groups you would like to directly invite to the folder, and set their folder permissions.
- Click Create.
Update folder name or description
To update the name or description of a folder:
- Open the file browser by logging in to your account at figma.com. If you’re inside a file, click the Figma menu > Back to files.
- View a list of folders on your plan or team.
- On the Organization or Enterprise plan, select All teams from the left sidebar. Then, select a team.
- Open the folder you want to update.
- Next to the folder name, click Open folder dropdown.
- Click Settings.
- Update the folder name or description.
- Click Save.
Change a folder’s color
To update the color of the icon for a folder:
- If you’re inside a file, click the Figma menu > Back to files.
- Open the folder.
- Select Change folder color.
- Select a new folder icon color.
Duplicate a folder
You can duplicate a folder to create a copy of its files and nested folders in the same location.
In order to duplicate a folder, you must have a Full seat. You also need can view access or higher on the folder, and also have an edit role on the team or folder that contains it.
When you duplicate a folder:
- Files in the folder are copied into the new folder
- You become the owner of the new folder
- Nested folders you have at least
can viewpermission to are also copied - The folder’s audience access setting is coped to the new folder, so anyone who had access that way can also see the copy. Individual roles are not copied, so anyone who was directly invited needs to be invited again.
To duplicate a folder:
- Right-click the folder you want to duplicate and select Duplicate.
Duplicating a folder may take a few moments. Once it’s complete, the new folder will appear in the same parent folder or team.
Share a folder
You can invite users to an existing folder at any time.
- If you have
can editpermissions on a folder, you can invite other users to the folder withcan editorcan viewpermissions. - If you have
can viewpermissions on a folder, you can only invite others withcan viewpermissions.
To invite others to a folder:
- Open the folder.
- Click Share.
- In the Share modal, enter an email address or user group name in the invite field, then set their folder permissions.
- Click Invite.
You can also click Copy link from the share modal to share a direct link to the folder.
Folder permissions
When you share a folder, you choose what that person can do with the files inside it. Nested folders inherit user roles from their parent folder by default—so if someone is directly invited to a parent folder, they automatically have access to its nested folders too.
For a full breakdown of folder permission types and how they interact with team and organization-level access, see File and folder permissions.
