While handing off designs to developers frequently happens after a major project milestone, here are some things you can do earlier in the design process to set up your files to improve handoff.
Set up files for Collaboration
Tip: Want to learn how other companies approach developer handoff? Read A Guide to Developer Handoff.
There are lots of different ways to collaborate in Figma. We've rounded up a few tips that we've used ourselves, or seen in action.
Files
- Right-click any frame and set a custom thumbnail so you can identify files at a glance. The thumbnail can also include information such as the project's current status.
- Link to Figma Design files in your project specification documents or project plans.
- Create "sticky note" components and add them to the canvas to explain or draw attention to design decisions.
- Apply Export Settings to frames, Components and Assets your Developers may need to export for the final production build.
Pages
- Name pages descriptively to let others know what's ready for development.
- Create a single page with Instances of all your components. Collaborators only have to check this page, as you make changes to your components.
- Right-click on a component and choose Move to Page or check out the Component Page plugin.
Sections
- Organize files with sections for easier navigation.
- Mark content as “Ready for development” to help with developer handoff.
Styles and components
- Give Styles relevant and descriptive names.
- Add component documentation to your design system. Collaborators can use Go to Main Component to learn more about how to use it.
- Name layers and components based on their IDs
Add meaningful descriptions to components:
- When and how collaborators can use them
- Any variants or states
- Accessibility and contrast guidance
Want to a bit more detail? Check out our Tips for a better developer workflow post.
Invite collaborators to files and prototypes
You can invite collaborators to a prototype, or to the file itself.
When inviting someone to a file, you can choose to give them can view or can edit access. In most situations, inviting a collaborator with can view access will be enough.
Users with view access can:
✅ Select layers from the Layers panel or canvas
✅ View properties of selected layers in the Inspect panel
✅ Copy text content from Text objects
✅ Measure distances between objects in the canvas
✅ Add or reply to comments in files and prototypes
✅ View Prototypes in Presentation View
✅ Access components via the Go to Main Component link
✅ Link Dev resources to layers in Dev Mode
Note: You have the option to allow users with view access to copy and share the contents of a file. If you enable this, those with view access will not be able to explore or export assets from a file.
