Before you Start
Who can use this feature
Supported on any team or plan.
Anyone with at least can view access to a file can add and view comments
Comments takes collaboration to the next level. You can use comments to respond to feedback, tweak your designs and iterate faster—all from the original design file.
When you and your team add comments to a file, they're displayed on the canvas in the regions or locations they were added to. You can view and reply to comments right from the canvas using the browser, desktop, and mobile app. You can also view and manage comments from the right sidebar when you enter comment mode.
Comments can be hidden from your canvas at any time ↓
View comments
From the canvas
Comments in a file are pinned to the point or region of the canvas selected by the commenter. How comments display depends on your zoom level of the canvas and the amount of comments.
- Pins: Individual comments are represented by a . Hover over a pin to preview the comment. Click the pin to open the comment modal, where you can reply.
- Clusters: As you zoom on the canvas, multiple comments that are pinned closely to each other are consolidated into clusters. Hover over a cluster to preview the amount of comments and avatars for their authors. Click on a cluster to focus on the comments within it, then hover or click on individual comments to view them.
Click on the comment to open the comment modal. From here, you can:
- Hover over the comment body to activate the to use a reaction.
- Click to Mark as unread, Copy link to the comment, or Delete the thread if you added the comment. Click to Resolve the comment, and to close the comment modal.
- Type a Reply to the comment, then click to Submit.\
Tip: To keep a comment visible while you make edits to your designs, drag it to a new part of the canvas.
Hide comments from the canvas ↓
From the right sidebar
You can also access and manage all comments in a file by clicking in the main toolbar or pressing C to enter comment mode. From here, you can view, search, sort, and filter comments. Click on a comment in the right sidebar to open it in the canvas.
When you're viewing comments in the right sidebar, each comment will include the page it's located in. When you click a comment to open it, you'll be navigated to that page and the location of the comment.
Note: When you're in comment mode, you won't be able to make any changes to objects in the canvas. Press Esc or select another tool to continue editing a file.
Hide comments
Comments are always visible on the canvas by default, whether or not you're in comment mode. If you rather hide comments from your canvas and only see them when in comment mode, you can do so at any time.
To hide comments, use the keyboard shortcut ⇧ Shift C to toggle them on or off. Press to show and hide comments in the Figma mobile app.
Sort and filter comments
All the comments in the file will be listed in the right sidebar when you're in comment mode. Click at the top of the right sidebar to sort and filter which comments you'd like to view.
Comments in the right sidebar can be sorted by:
- Date: displayed in order from the first comment in a thread
- Unread: displayed by date, prioritizing comments that haven't been read
- Click at the top of the right sidebar.
- By default, comments are sorted by Date. Click Sort by unread to prioritize unread comments.
- By default, the sidebar will display all comments in a file. Check Only your threads to view the comments that are relevant to you. This includes:
- Comments you have been @mentioned in.
- Comments on threads you've replied to.
- Comments you've created that collaborators have replied to.
- You can also decide if you'd like to Show resolved comments. Click on the setting to turn it off and on.
Learn how to edit and move comments →
Reply and react to comments
Anyone can add, view, and reply to comments, including viewers.
- Select the comment in the canvas, or from the right sidebar.
- The comment box will appear with a Reply field attached. Click Reply and start typing in your message, or hover over the body and click to react to the comment. You can also add any emoji or @mentions as needed.
- Click or press Return / Enter to add your comment to the thread.
- Add further replies to the thread as needed.
Tip: You can also reply to comment notifications from our Slack or Microsoft teams integrations.
Resolve comments
Once the feedback has been addressed, or a resolution reached, you can Resolve the comment.
This will hide the comment from both the right sidebar and the canvas.
- Click in the top-right corner to mark it as Resolved.
- We will hide the comment from both the right sidebar and the canvas.
Unresolve comments
If a comment is resolved by mistake, you can undo this action by unchecking the in the comment. Click in the right sidebar when in comment mode and toggle the Show resolved comments filter on.
Learn how to sort and filter comments ↑
Delete comments
You can also delete any comment you post. If you delete a comment with replies, this will delete the entire thread.
Caution: Deleting a comment is a permanent action. It's not possible to restore a deleted comment, even if you restore an earlier version of the file.
Delete a single comment
- Click next to the comment.
- Choose Delete comment from the options.
Delete an entire thread
You can also choose to delete an entire thread. This will delete both the initial comment and any replies.
- Click next to the comment's title.
- Select Delete thread from the options.
- Click Delete to confirm.
