Before you start
Who can use this feature
Supported on any team or plan
Anyone with can edit permissions on a Figma file can use the Storybook plugin in Design Mode or Dev Mode
Storybook is an open source tool for developing, testing, and documenting UI components across many. Use Storybook to:
- Create code-based components that can be used across different platforms and devices.
 - Collaborate with designers, engineers, and product managers.
 - Showcase components in an interactive development environment, without needing to spin up the full application.
 - Show different use cases and examples for implementing components.
 - Install addons for prototyping, testing, and documentation.
Connect Storybook to Figma to view your designs in Storybook and view your stories in Figma.
The design addon for Storybook allows you to embed Figma files alongside your code-based components in Storybook. Meanwhile, the Storybook plugin for Figma allows you to embed stories alongside your design components in Figma. Storybook for Figma can be used by designers in Design Mode or by developers in Dev Mode.
Learn more about Storybook in their docs and tutorials.
About the Storybook plugin
Figma Storybook plugin lets you embed component stories in Figma. This lets you cross-reference the live implementation from Storybook in your Figma file. The Storybook plugin is powered by Storybook embeds and Chromatic, a publishing tool created by the Storybook team.
Before embedding Storybook in Figma you'll need:
- Your Storybook project is published on Chromatic
Can editpermissions in Figma - Be listed as a collaborator in Chromatic
To connect Storybook to Figma, you will need to install the Storybook plugin in Figma: Design or Dev Mode.
Embed Storybook in Figma
In Storybook
- Sign in with Chromatic.
 - Go to a story in a Storybook that is published on Chromatic.
 - Copy the URL for the story from the address bar.
In Figma
- Open a Figma file in Design or Dev Mode.
 - Run the Storybook plugin in Figma.
 - Select the Figma component you want to link the story to. The Storybook plugin supports linking stories to Figma components, variants, and instances.
 - Paste the URL into the plugin modal.
 - Click Link story.
 - Figma will show links to the story in the right sidebar. If a component was linked, all instances of that component will have the link.
Open a story in Figma
- In Figma, select a component that you’ve previously linked to a story.
 - Click view story in the right sidebar.
 - or run the Storybook plugin.
Embed Figma in Storybook
Storybook design addon allows you to embed Figma files and prototypes in Storybook. It’s powered by Figma Live Embeds. You can embed Figma files in Storybook, regardless of the file's sharing settings. Share private files within a team, or public files with the world.
Collaborators can interact with embeds based on their team or Organization permissions.
Install the addon:
npm install -D @storybook/addon-designs # yarn add -D @storybook/addon-designs
Register the addon in your .storybook/main.js file:
// .storybook/main.js module.exports = { addons: ['@storybook/addon-designs'] }If you're using Storybook@5.0.x, use this module instead.
// .storybook/addons.js import 'storybook-addon-designs/register'
For detailed instructions, check out the Figma addon readme on GitHub.
Copy the Figma URL
Copy the URL for the file or frame you’d like to embed in your story.
- Open the Figma file.
 - If you want to share a specific frame, select the frame on your canvas.
 - Click the Share button.
 - Click the Copy link button.
Paste the Figma URL in Storybook
Use a parameter to associate Figma files and frames to your story.
- Open your stories file (in many cases, it’s named like *.stories.js)
 - Add a story parameter named design:
export const myStory = () => <Button>Hello, World!</Button>myStory.story = {
parameters: {
design: {
type: 'figma',
url: ''
} - Paste the copied URL to the URL field.
Open a Figma file in Storybook
- Open Storybook
 - Open the Design tab in the addon panel.
 - Click the embedded Figma file to open it.
