At Config 2026, we expanded what's possible on the Figma canvas: new materials like motion and shaders, tools you can build yourself, and a more powerful agent to support your work. Get an overview of everything we launched at Config 2026 over on our blog.
This article walks through each feature we announced, including availability status and how to get started. Some features are in beta or coming soon. We'll note availability for each below and keep this article updated as things change.
Here's what's new:
- Figma Motion
- Custom shader effects and fills
- Weave tools in Figma Design
- Updates to the Figma agent in design files
- Generative plugins
- Code layers (closed beta)
Are you an admin for a team or organization? Check out the admin’s guide to Config 2026.
Figma MotionOpen beta
Before you start
Who can use this feature
Available for Full seats on all plans
Creating and editing motion requires can edit access to the file.
Create production-ready animations directly in your design files with Figma Motion.
- Animate your designs: Quickly add motion with preset animations, or build your motion from the ground up with keyframes.
- Fine-tune your motion: Use easing curves and spring animations to shape how your motion feels.
- Generate a first pass with the Figma agent: Describe the motion you want and let Figma agent add keyframes to the timeline. Then refine the details manually or keep prompting until the motion is just right.
- Build your motion system: Maintain consistency across your motion system with timing and easing variables and animated components.
- Ship your animations: Use the read-only timeline in Dev Mode to inspect animations at full fidelity, then copy code into CSS, JSON, or React. Or send animation context to your coding tools via the Figma MCP server.
Learn more about Figma Motion.
New to motion design? Check out the Motion design fundamentals collection to learn the principles behind effective motion design and gain hands-on practice creating animations.
Frequently asked questions
When will I get access to Figma Motion?
Figma Motion is rolling out gradually on June 24, 2026. If you don't see it in your account yet, check back soon!
Who can access Figma Motion?
Figma Motion is available on all plans in Open beta. You can access Figma Motion in any design file you have can edit access to by switching the toolbar toggle to Motion.
Publishing animated components, generating animations with the Figma agent, and high-resolution video exports require a Full seat on a paid plan.
Figma Motion is not available on Figma for Government plans.
Does Figma Motion consume AI credits?
Figma Motion doesn't use AI credits directly, but using the Figma agent to create motion will use AI credits in the future. Currently, while the Figma agent is in beta, it does not use AI credits. Once the agent is generally available, standard AI credit usage will apply. Manually editing agent-created motion never consumes credits.
What export formats does Motion support? Do you plan on supporting more in the future?
Export Figma Motion files as MP4, GIF, WEBM, or Animated SVG. We will introduce additional formats in the future, including Lottie.
Custom shader effects and fillsOpen beta
Before you start
Custom shaders are available in Figma Design, Figma Draw, and Figma Motion on paid plans
Using a custom shader requires can edit access to the file
Figma-created shader effects and fills are available on all plans
Prompt to build custom shader effects and fills you can save and reuse to create striking visuals, add personality to your designs, and help your brand stand out.
- Native creation tools: Create shader effects directly in Figma Design with prompts
- On canvas controls: Shaders use Figma’s UI so they feel like native properties
- Natively rendered: WebGPU shaders as custom effects, making it possible to build new fills
Learn how to build custom effects and fills.
Do I have access to custom shaders?
Creating shaders via the Figma agent is gradually rolling out to users with a Full seat on a paid plan as an open beta on June 24, 2026. Using Figma’s first party agent-built shaders are rolling out to users with a Full seat on all plans in open beta.
Creating shaders via the Figma agent is not available for Education, Government, or Starter plans.
Do I need to know how to code to create shaders?
No. Shaders can be prompted through chatting with the Figma design agent. You describe what you want and the design agent generates the shader for you.
Do shaders consume AI credits?
As of now, shaders do not consume AI credits. Once the Figma agent becomes generally available, standard AI credit usage will apply to build shaders with the agent. It does not consume AI credits to apply shaders.
Can I use shader effects in other Figma products?
Yes. Shader effects support export to Figma Make and other platforms via MCP.
- PNG will always work for a fixed frame
- MP4 export will work in Motion with Shaders
- MCP (crude/raw) code export will be supported
- This means that devs will have access to the JS/WGSL
Shader effects do not currently appear in Dev Mode, but this is something our product teams are actively exploring.
Figma Weave
You can now use Weave tools in Figma Design to generate visuals in a design file and use pre-built workflows for Weave from the Figma Community.
Weave tools in Figma Design Open beta
Before you start
Available on Professional, Organization, and Enterprise plans
Using a Weave tool requires can edit access to a file
Learn more about Figma Weave
Plug inputs into the straightforward UI of Weave tools in Figma Design and generate quality assets on repeat – without the need for robust prompting. Weave tools make it easy to quickly execute on common AI image tasks, like replacing a background, adding a logo to a product, and changing the aspect ratio of an image.
- Choose from a curated list of Weave tools in Figma Design to accomplish simple AI image generation task
- Weave tools are backed by powerful AI workflows, saving you from having to write new prompts yourself
- Swap out inputs and receive consistent results every time you run a Weave tool
Learn more about using Weave tools in Figma Design.
Weave workflows on Community Generally available
Before you start
Available for Full seats any plan
Requires can edit access to a file
Find and create Weave workflows—either as a tool or a template file—for others to use on the Figma Community.
These files let you:
- Duplicate proven Weave workflows into your workspace
- Learn how workflows are structured
- Have a starting workflow to change or add to based on your own creative needs
- Create and share your own workflows with your team or others
Learn more about Figma Weave workflows in the Figma Community.
What is the difference between Weave tools in Figma and Weave as a standalone product?
Weave is Figma's platform for generative AI and professional editing tools on the open canvas, spanning image, video, animation, motion design, and VFX.
Weave tools in Figma bring that power directly into your design workflow, with a simple UI for common AI image tasks so you can generate consistent results without leaving Figma.
When will I get access to Weave tools in Figma?
Weave tools in Figma are rolling out gradually to Professional plans and above with Full seats on June 24, 2026. If you don't see one of the new features in your account yet, check back soon!
Do I have access to Figma Weave tools in Figma Design?
Available to Professional plans and above with Full seats. Weave workflow templates on Community are available to all plans with Full seats. Weave tools in Figma Design are not available for K-12 Education, Government, or Starter plans.
Do I have access to Weave workflow templates on the Community?
Weave workflow templates on Community are available to any users on any plan who have a Figma Weave account.
Do Weave tools in Figma Design consume AI credits?
As of now, Weave tools in Figma Design will not consume AI credits.
Does Figma Weave consume AI credits?
Yes. Each plan on Figma Weave includes a monthly allocation of Figma Weave AI credits that you spend when creating content with different AI models. Learn more here about Weave pricing plans.
Updates to the Figma agent in design filesOpen beta
Users with Full seats can chat with the agent in Figma Design files
Using the Figma agent requires can edit access to the file
Now in open beta, collaborate with the Figma agent in design files to generate and remix designs, automate busywork, and get design feedback.
What's new with the Figma agent:
- Create and manage custom skills: Turn your team's workflows, conventions, and preferences into shareable skills that can be run on demand
- Search the web: The agent can search the web and fetch content from URLs, so you can ground your designs in real-world, up-to-date information
- Connect to external tools using MCP connectors: The agent can connect to external tools via the Model Context Protocol (MCP), allowing you to pull context into your designs and write back to external sources
- Attach files: Attach Figma files, images, text and code files, and PDF and spreadsheet files to your prompts so the agent has specific references it can use to produce better results
Starting June 23, new conversation threads with the agent in Figma Design are visible by default to people within their organization or team with a Full seat and edit access to the file. Threads created before June 23, 2026 remain private unless you make them public. Learn more.
New to using AI in your design workflow? Check out our Using AI in your design workflow collection for ideas, hands-on examples, and best practices for using AI across a broad design workflow.
Learn more about using the Figma agent.
Do I have access to the Figma Design agent?
Updates to the Figma agent are rolling out gradually on June 24, 2026. If you don't see one of the new features in your account yet, check back soon!
The agent is available to the following Figma Design users:
- Full seats can use the agent in all Figma Design files
- View, Dev, or Collab seats can try the agent in Draft files
- The agent is included on the Professional, Organization, or Enterprise plans with AI features enabled
- The agent is not available on Education, Government, or Starter plans
Does the Figma Design agent consume AI credits?
The agent is free during the beta period. AI credits won't be consumed for any prompts or actions. When the agent is generally available, Figma’s AI credit system will apply.
Are there admin controls to manage how my team or organization uses the Figma agent?
Yes, Figma admins can disable AI tools for everyone in their team or organization. Learn more about managing AI feature access and settings as an admin.
Generative pluginsOpen beta
Before you start
Generative plugins are available in Figma Design, Figma Draw, and Figma Motion on paid plans
Using generative plugins requires can edit access to the file
Figma-created plugins are available on all plans
Prompt the Figma agent to build reusable plugins right in your file that feel native to Figma. Create custom tools that support your unique workflow, like reordering or sorting layers by criteria, applying consistent spacing or padding across selections, or finding and replacing text or colors across a file.
- Prompt-to-create: Build custom plugins by chatting with the Figma agent
- On canvas controls: Plugins use Figma’s UI so they feel like native tools
Learn more about generative plugins.
When will I have access to generative plugins?
The ability to create generative plugins are rolling out gradually on June 24, 2026. If you don't see one of the new features in your account yet, check back soon!
Can I still build plugins without the agent?
Yes — the agent introduces an additional path to building plugins. Classic plugins aren’t going anywhere and we’re continuing to invest in resources for developer plugins. Additionally, we’re investing more in new plugin APIs and new plugin UI; these investments will be available to both generative plugins and classic plugins.
Who can access the plugins I build with the agent? Can I publish one to the Community?
At launch, generative plugins live in your file and are accessible to anyone with access to that file. The plugins you create are also available across all your own design files. We plan to bring public publishing to Community and private publishing to your organization in the coming months.
Where do generative plugins run? Who hosts them?
Generative plugins are hosted by Figma. They are written and run right inside your Figma file. Classic plugins are built on your local machine using the Figma desktop app and a development environment like Visual Studio Code or Cursor, and then published to the Figma Community where other Figma users can discover and run them.
Do generative consume AI credits?
As of now, generative do not consume AI credits. Once the Figma agent becomes generally available, standard AI credit usage will apply to build plugins with the agent. It does not consume AI credits to run an generative plugin.
Code layers Closed beta
Note: This feature is currently in closed beta, but will be available more broadly soon. Stay tuned!
Bring working code into the Figma canvas as a new kind of layer: code layers.
- Figma collaboration, now with code: Create and compare interaction ideas side by side, refine details, and get feedback from your team
- Move between mediums: Convert code layers into design layers for editing, and design layers into code layers for building
- Connect your codebase: Upload a local codebase or clone your GitHub repository to start prototyping from existing code components and pages
Sign up to join the waitlist for early access to code layers.
Sign up to get early access to our other announcementsEarly access sign-up
We showcased some exciting tools coming to Figma soon. You can apply for early access to these tools with one request using this form.
- Code layers: Design with code on the Figma canvas
- 3D transforms in Figma Design: We are bringing native 3D transforms to Figma, from editable spatial design to dev-ready export
- Figma agent across the Figma platform: Use the Figma agent across FigJam and Figma Slides
Waitlist frequently asked questions
How do I join the waitlist?
You can join the waitlist using this form.
After submitting the form, you’ll receive an automated confirmation email letting you know that your request was received. While joining the waitlist doesn’t guarantee immediate or early access, it helps our team understand your interest in the feature(s).
How can I tell if I’m on the waitlist?
Once you’ve added your name to the waitlist, you’ll receive an email confirmation that verifies you are on the waitlist. If you aren’t sure whether you have signed up yet, check your email for the confirmation.
This doesn’t guarantee early access but will let our team know that you’re interested.
Can I request my whole team or organization get access?
Access is evaluated on a feature-by-feature basis. Depending on the feature and its rollout plan, access may be granted to an individual, a team, or an entire organization. If you're selected for a beta, we'll communicate the scope of access as part of the onboarding process.
Watch all of Config 2026
If you weren't able to make it live, check out the keynote from Config 2026 and catch up on the recordings on our YouTube channel. We’ll be posting more videos in the coming week, so be sure to subscribe to stay up to date!
