Who can use this feature
Starter, Professional, Education, Organization, and Enterprise plans
Figma Motion is currently in open beta. Features may change and you may experience performance issues as we continue to improve Figma Motion. Learn more about what's included in the beta.
You can turn animations created in Figma Motion into reusable components and publish them to your design system. Learn more about Figma Motion.
Create animated components
You create animated component the same way you’d create any standard component. Learn more about components.
Note: Components can currently only be created in Design mode.
To turn an animation into a main component:
- Switch the toolbar toggle to Design.
- Select the layers you want to include in the component.
- Do one of the following:
- Click Create component in the right sidebar
- Right-click on your selection and choose Create component
- Use the shortcut:
- Mac: Option Command K
- Windows: Ctrl Alt K
Figma will nest the layers within a special component frame. Identify components in the Layers panel using the purple Component icon. You can use the Component configuration settings to add a description and documentation link for collaborators.
Note: Publishing animated components to a library is available on the Professional, Education, Organization, and Enterprise plans.
Once created, you can publish animated components to a library to build your motion system. Learn more about libraries.
Use animated component instances
Animated component instances behave like regular instances, except that you can also view them on the Figma Motion timeline.
Animated instances appear as purple layer tracks on the timeline. You can drag to reposition them on the timeline, but the animation’s duration and properties can only be edited at the main component level. Learn more about creating and inserting components instances.
Note: Component properties cannot be modified while in Figma Motion. Switch the toolbar toggle to Design to modify an instance’s component properties.
