Who can use this feature
Starter, Professional, Education (not K-12), Organization, and Enterprise plans
Requires access to a shader as its creator or an invited publisher
Find your shader
- Open the workspace where your shader lives.
- From a Figma Design file, navigate to the Tools tab in the navigation bar on the left and locate your shader.
- Narrow your search by using the Source filter and selecting Created by you.
- Narrow your search by clicking Filter by price and type and selecting Shader effect or Shader fill.
Update your shader
Make edits
Note: Editing a shader with AI requires access to the Figma agent. This is separate from renaming, managing a Community listing, or publishing an update.
Update your shader from the agent or from the Tools panel of any Figma Design file.
- Click the Tools tab in the navigation bar.
- Use the search bar to find your shader by name. You can also use the Source dropdown to filter by Created by you.
- Describe the edits you’d like to make, like
Add a control that.... - Press
Enterto submit your prompt. - Test your tool and iterate as needed.
Tip: Test things often, and test it in various situations. If using real designs, make sure to use a duplicate of the design to preserve the original asset. Get more prompting tips.
Rename
To rename a shader:
- Use the search bar to find your tool by name. You can also use the Source dropdown to filter by Created by you.
- Hover over your shader and click , then select Rename.
Publish a new release or edit the Community page
Once Figma approves your shader, you don't need to submit your shader for further review. This means you can publish any updates immediately.
If you've updated your shader and are ready to release the new version, you can publish an update. Doing this will update the shader for every user. Users who have already installed your shader will only have access to the latest version of your shader.
It's not possible for users to revert to a previous version of the shader. If you need to roll back any changes, you can republish an earlier version of the shader.
The process for submitting an update is the same as the publishing process for shaders. You can update any information about your shader, including the name, description, tags, and any artwork.
- Find your shader in the Tools tab of your design file.
- Next to the shader, click > Publish > Publish changes.
- Use the publish shader modal to update shader information as needed. Click Publish to complete the process. Figma will update the shader for everyone that has it installed.
Invite additional publishers
Once your shader is published to the Figma Community, you can invite others to help publish updates to your shader. Learn how to invite additional publishers.
Remove your shader
Unpublish
If you're a creator of a shader, you can remove it at any time.
If your shader is published to the Figma Community, unpublishing your shader will remove it for anyone who has installed it. Users who've installed your shader won't receive a notification if it's been unpublished.
We recommend warning your users of your plans to unpublish the shader. For example, you can add a note to the shader description or your personal website with the date you will unpublish the shader.
- Next to the shader, click > Publish > Unpublish.
The shader will be removed from the Figma Community and users will no longer be able to use the shader or view the listing. The shader will remain in development on your account.
Warning: When removing a shader from the Community, likes and installs will be retained, but any details—such as title, tagline, description, and so on—will be lost.
Delete a shader
If you decide to cease building a shader, or want to start from scratch, you can remove the shader. This will delete the shader from Figma.
- Next to the shader, click > Delete.
Caution: It's not possible to restore a deleted shader. Deleting a shader will also remove any likes and installs you have acquired, even if you publish the same shader in the future.
Cancel your shader under review
Every shader that gets published to the Figma Community goes through a review process first. You can make updates to your shader at anytime, even while under review. If you've changed your mind and no longer wish to share the shader to the Figma Community, you can cancel the review.
- Next to the shader, click > Publish > Cancel review.
Access version history
Note: Only the creator of a shader can view and restore its version history.
Version history allows you to view a record of changes to shaders that you created, and restore them to previous versions.
Versions are automatically created after each edit is made to your shader and are paired with version descriptions generated by the Figma agent based on what changed.
Any shaders published to your organization or the Figma community are also labeled, noting its version and where it’s been published. If you unpublish a shader, the unpublished versions won’t display a published label.
For shaders, there are two ways to access the version history.
Tools tab
To access version history for your shader from the tools tab
- From your Figma design file, locate your shader from the Tools tab in the navigation bar on the left.
- Click next to your shader and select View version history.
Shader settings
While you’re configuring shader settings on a layer, you can access your shader’s version history directly from the shader’s settings. Click and select View version history.
Restore a previous version
To restore a previous version of your shader:
- Access the shaders’s version history and find the version you wish to restore.
- Hover over the version, click , and select Restore this version.
Provide support
Figma does not provide support for third-party applications. As the shader's creator, it's your responsibility to assist your shader's users with technical issues.
You need to add a Support contact when you submit your shader for approval. This can be an email address users can contact, or a link to a website or help center.
