Who can use this feature
Starter, Professional, Education (not K-12), Organization, and Enterprise plans
Code layers in Figma Design is in open beta.
A code layer is an interactive prototype backed by running code that sits directly on the canvas. With code layers in Figma Design, you can:
- Create realistic design and code explorations all in the same environment, because both code and design sit on the canvas of the same file.
- Evaluate variations of a design experience side-by-side instead of switching branches by duplicating a code layer, prompting a different direction, and compare several running versions at once.
- Preview interactive designs directly on the canvas to capture empty, loading, and error states. Update them, and push updates back to the code layer and even your codebase.
- Start from your team's codebase instead of a blank prompt. Explore, iterate, and review real, front-end prototypes without handoff or committing to engineering resources.
Get started with code layers
Code layers can be created in any Figma design file. There are a few ways to get started with code layers:
- Start from scratch: Add an empty code layer on the canvas and prompt the agent to build
- Start with designs: Select design frames on the canvas, and prompt the agent to turn them into a code layer
- Capture code from your webpage: Use the Figma extension to copy code and paste it onto the canvas as a code layer
- Connect a GitHub repo: Clone a connected GitHub repo to build on top of an existing frontend codebase
- Upload a local folder: Import your code files directly from your computer
Start from scratch
Add an empty code layer on the canvas and prompt the agent to build. To do this:
- Select Code from the toolbar, or press B on your keyboard.
- Click and drag on the canvas to create the layer, or select a frame size in the right sidebar.
- Open the Figma agent and type a prompt describing what you’d like to create in the code layer.
Tip: Duplicate any code layer to explore a new direction side by side.
Start from designs
To turn any frame on the canvas into an interactive code layer:
- Select a frame on the canvas.
- From the right sidebar, click Build selection.
You can also turn multiple designs into code layers simultaneously by selecting multiple frames and prompting the agent.
Tip: Adding prototyping connections to your designs will help the Figma agent build more accurate interactions for your code layer. Get started with prototyping in Figma.
Start from your webpage
Use the Figma Chrome extension to copy code from your webpage and paste it into a Figma file as a code layer. Download the Figma extension from the Chrome web store.
- Navigate to your webpage, then click in your Chrome toolbar.
- In the toolbar that appears, click Capture code.
- Once the code is copied to your clipboard, open a Figma Design file and paste with ⌘ Command V (Mac) or ControlV (Windows/Linux).
The capture is placed on the canvas as a code layer.
Connect your code source
If you’re already coding in a third-party environment and don’t want to hop back and forth between tools, or you want to see explorations side-by-side in the same place, you can connect a code source so that the code layer uses your real production code.
The best way to use your own code with code layers is by cloning repositories hosted on GitHub. After connecting Figma to one or more GitHub organizations or accounts, you can select a repository to clone for your code layer. Figma stores the clone of your repository so you can make changes, utilize multiple branches so you can experiment, and then create pull requests to merge your improvements back into the original repository.
Learn how to connect your code source to code layers.
Note: Code layers don’t work with every repository. Before you clone, check the repository requirements and limits.
Play a code layer
To interact with the contents of a code layer, select the code layer and press Play in the top-right corner of the layer. This allows you to try out different flows and test the experience to see if changes are needed.
You can play multiple code layers on the same page at once.
Tip: Preview a code layer in the Figma mobile app to test interactions on a real device.
Tip: Place multiple code layers side-by-side on the canvas to evaluate different versions of a flow or interaction.
Edit a code layer
Prompt the Figma agent for any changes you’d like to make to a code layer. You can also open the code editor and use point and edit.
Once changes are made to the code layer, you may need to click Reload code layer to see the changes.
Open the code editor
To access the code editor:
- Select the code layer.
- Click Open code editor in the top-right corner of the layer, or from the secondary toolbar at the bottom of the file.
From there, you can view the code layer's code, embed comments into the prototype, and edit designs directly.
To exit the code editor and return to the file, click back in the top-left corner.
Point and edit
The edit tool opens a Figma Design-style properties panel in the code editor and lets you point to elements in your functional prototype or web app. When you select an element, depending on the type of element and the way it was generated, you can modify properties such as colors, padding, margins, text styling, and more.
To use the edit tool:
- Select the code layer and open the code editor.
- Navigate to the Browser tab at the top of the file.
- In the upper-right corner, click Edit near the top-right of the file.
- In the preview, click the element that you want to modify. Drag your cursor or hold ⇧ Shift while clicking to select multiple elements.
- Make changes using the properties panel. As you make adjustments, the changes appear above the prompt box in the agent chat.
- In the chat, click Apply. The agent applies the changes you made to the code layer.
Extract a code layer to design
Extract designs allows you to turn code layers into editable design layers on the canvas. If updates are made to those layers, the changes can be pushed back to the main code layer.
When you have a code layer selected, you’ll have an Extract designs option in the secondary toolbar at the bottom of the file. There are a few ways to extract designs from a code layer:
- Current state: Extracts the whole page inside the code layer as it currently looks
- Select element: Extracts a selected element on the code layer
- Record a flow: Interact with the code layer and Figma will create multiple frames to represent the sequence of screens in that flow
Use shaders in code layers
Shaders allow you to create complex visual effects—such as blurs, glassy distortions, and realistic animated fire.
Shaders are supported in code layers, including interactive and animated shaders. This allows you to get a realistic idea of how your shader behaves in context of the rest of your designs when everything is backed by code.
Before you use shaders in code layers, make sure to:
- Use the Chrome browser. Shaders in code layers is not supported in the Figma desktop app and other browsers running on Chromium.
- Enable the HTML-in-Canvas Chrome API here:
chrome://flags/#canvas-draw-element
Once these requirements are met, you can turn a shader into a code layer the same way you would turn a static design into a code layer. Once the code layer is built, press Play in the top right corner of the code layer.
Use the MCP with code layers
With the Figma MCP server, you can now move a project from your coding agent straight into a Figma Design file as a code layer. Your agent packages the project and imports it onto the canvas. From there, you can keep iterating with the Figma Make agent, pull designs from it, and share it with your team, all in the same file as your designs.
To get started, be specific in your prompt, like:
Import this project as a code layer in <Figma file URL>
Imports can take 10 minutes or more, and some projects may need changes to run in a code layer.
Importing a project as a code layer through the MCP server requires a Full seat. The import itself doesn’t use Figma AI credits, but prompting the Figma Make agent to make changes afterward does. Learn more about the Figma MCP server tools.
Frequently asked questions
When will I get access to Code layers?
Code layers is in open beta on all plans. Once the feature is available in your account, you’ll see a Code icon in your toolbar in Figma Design. If you don't see code layers, refresh the tab you're in or restart the Figma desktop app.
Do code layers consume Figma AI credits?
Code layers will use AI credits in open beta. The number of credits for code layers will vary based on the complexity of the task. Learn more about how AI credits work.
How many Figma AI credits do code layers consume?
Credit consumption varies based on a number of factors, including the complexity of the task. Learn more about how AI credit consumption works for code layers.
Can I turn off code layers? Can I opt out?
Only Enterprise plans can opt out. Enterprise admins can disable code layers by turning off AI features from their team or organization settings. Turning off AI features also turns off all other AI features across Figma. Learn how to disable AI features.
