Who can use this feature
Government and Enterprise plans with the Governance+ add-on
Admins only
Requires domain capture
By default, members of a Figma organization can create and edit files outside the organization. For example, they can join files shared with them from people at other companies, or create new files in Starter and Professional teams outside the organization.
By restricting access to external content, organization admins can keep everyone’s work inside the company Figma organization. When access to external content is disabled, members can’t:
- Create new files or folders outside your organization.
- Edit files they’ve created outside your organization.
- Edit or comment on files shared with them from people outside your company.
- Accept new invites to join files, folders, or teams from outside your company. The exceptions are open sessions in FigJam, public files, and password protected files. In these cases, people can join the files with view-only permissions.
Note: When this setting is enabled, everyone's permissions will change to view-only in files they have access to outside of your Figma organization. This includes drafts they’ve made in other organizations or in Starter and Professional teams outside your organization.
Let people know about the change in advance
Before limiting access to content outside your organization, we recommend telling people in advance what they can expect. Here’s a customizable message template you can use to prepare everyone for the change.
Hi team,
On [date], we're going to change an important setting in our Figma organization. In an effort to keep [company name]’s creative work inside our organization, we're going limit editing access to content from outside our company.
Here's what you can expect on [date]:
- Any existing files, folders, and teams shared from outside our company will switch to view-only.
- You won't be able to accept new invites to join files, folders, or teams shared outside our company.
- You won't be able to create drafts, files, or folders outside of the [company] organization.
- Any drafts you've made outside of the organization will become view-only.
- You can still create and edit drafts within the [company] organization.
- You can still join open sessions in FigJam, public files, and password protected files from outside our organization with view-only permissions.
Before [date], please review any content you have access to outside our organization. You can click on the name of our Figma organization at the top left of the file browser to view other organizations or teams you have access to.
If you have content you need to move into our Figma organization, export or save a copy of each file to your computer, then import the files by dragging and dropping them in Figma’s file browser.
If you have questions about this change, please reach out to [person or process].
Restrict external plan creation only
If you want to prevent members from creating new Starter or Professional plans while keeping external collaboration available, use the External plan creation setting instead.
This separate control is included in the Enterprise plan.
When access to external content is disabled, external plan creation is also blocked. You can’t change the external plan creation setting independently while the broader restriction is in place.
Learn more about restricting external plan creation.
Enable or disable access to external content
Access to external content is enabled by default. Organization admins can disable access to restrict members’ work outside the organization, or enable access to remove the restriction.
- From the file browser, click Admin.
- Select the Settings tab.
- Under External access, click Access to external content.
- Change the setting.
- Click Save.
