We’ve made a few changes to how drafts work in Figma over the past few years. Here’s a brief overview:
- Before October 15, 2024: On the Starter and Professional plans, drafts were not associated with any specific team. You had a separate Drafts tab in the file browser that contained all your drafts, across all teams.
- October 15, 2024 through October 9, 2025: Drafts were moved into teams, and each team has their own Drafts space. Any drafts that were previously in the separate Drafts space were moved into a new temporary space called Drafts to move. From Drafts to move, you were prompted to move your drafts into an existing team’s draft space.
- Starting October 9, 2025: The Drafts to move tab will no longer be available. Any files still remaining there will be automatically moved into the Drafts section of a team on your account. Going forward, all drafts will live within a specific team.
What to expect
- You can continue working in drafts for free. Each team you’re a member of has its own Drafts section.
- Drafts in Drafts to move that you hadn’t moved manually will be relocated. Figma will automatically migrate them into the Drafts space of a team on your account.
- If there isn't an appropriate team to move them into, Figma will create a new, free Starter team for your drafts.
- You still own and control these files. Drafts remain private to you and anyone you choose to share them with.
- Some collaborator permissions may change. In most cases, collaborators will be set to
can view, but you can change editing permissions if needed.
Frequently asked questions
We want to improve clarity and consistency across Figma. Previously, drafts existed outside of any team, which made ownership unclear and created friction when trying to collaborate or manage files. By associating drafts with specific teams, it’s easier to find, manage, and share your files securely.
If you didn’t move them manually before migration, Figma will move them for you. You can find them in the Drafts section of:
- Your existing Starter team — if you only own one Starter team at the time of migration.
- A new, free Starter team — created for you and marked with a “New” badge, if you had multiple teams or no teams.
- Your Drafts space in your organization — if you’re part of a domain-captured organization with external collaboration controls (ECC) or using Figma for Government.
If you're unsure where they went, check your Recents tab or use search.
If you previously deleted your Drafts to move files, those files were migrated to the Trash section of the new Starter team they landed in.
- Check the Trash section of your new Starter team to find them
- From Trash, you can choose to restore or permanently delete files
If you didn’t already have a team to house your drafts, we will create a free Starter team for you. This team functions just like any other Starter team. You can move your drafts into a folder to collaborate or keep them in Drafts for personal work.
To move a draft from one of your teams to another:
- In the file browser, find the file you want to move.
- Right click the file thumbnail and select Move file…
- Select the All tab to see a list of all your teams.
- Select a team, then select either that team’s Drafts space or a folder.
- Click Move.
When you transfer a team, all its folders and files will move to the recipient’s organization.
When accepting the transfer, the recipient can choose whether to keep or remove access for everyone from the sending team or organization. The admin of the receiving plan must approve the transfer.
There are three steps to transfer a team:
You can choose to transfer the folder from the new Starter team to another paid plan on your account.
When you transfer a folder, all its files will move to the recipient’s team or organization.
When accepting the transfer, the admin of the receiving plan is required to accept the transfer. The recipient can choose whether to keep or remove access for everyone from the sending team or organization.
There are three steps to transfer a folder:
You can select which files you want to move between teams by downloading and importing them manually.
To save a local copy of a file:
- Open the file you want to export.
- Click Main menu.
- Go to File > Save local copy to download a copy of the file to your downloads folder.
To import a local copy of a file:
- Open the Figma account you want to import the file to.
- Drag the file into the file browser.
To switch between different teams on your account:
- Open the file browser by logging in to your account at figma.com.
- If you’re in a file, click the Figma menu > Back to files.
- Click the dropdown menu next to your team name on the left sidebar to see a list of your teams.
- Select a team.
Each team has its own Drafts tab which holds all your draft files associated with that team.
To view your drafts:
- Select a team.
- Click the Drafts tab.
- Drafts are private to you and live in your team’s Drafts space. You can experiment, create, and iterate here.
- Drafts on the Starter plan do not support collaboration with other editors, although they can be shared with unlimited viewers.
- When ready, you can move a draft to a folder to collaborate with your team.
- Files live in your team’s folders and support real-time collaboration with unlimited editors.
If a Starter team has the Locked label, it means the team has exceeded the limits of the plan. To understand why, navigate to the team with the label and click the banner at the top of the page. You’ll see advice for how to unlock the team.
