- Available on any team or plan
- Anyone with
can editaccess in FigJam can create and edit mind maps. - Check out the Guide to FigJam →
Mind maps are a great way to visually organize information into a hierarchy, showing relationships among pieces of the whole.
In FigJam, mind maps are composed of nodes, which are the text fields, shapes, or stickies representing an idea or step. Nodes on the same level of a hierarchy are siblings, while nodes on a lower or following level are children.
Use mind maps to:
- Create decision trees
- Brainstorm ideas and flows
- Visualize hierarchy for information, systems, and organizations
- Illustrate relationships and structures
Start a mind map
There are a couple ways to create a mind map:
Shape picker
- Click Shapes > Mind maps.
- Click the board to place you mind map.
- Build your mind map ↓
FigJam AI
Generate mind maps using FigJam AI.
- Click in the toolbar > select Make templates and diagrams.
- Click the text field and enter your own prompt.
- Click Make.
Check out prompting tips and suggestions for FigJam AI →
Existing text
- Create or select a text object on your board.
- Click the Mind maps icon in the selection toolbar.
You can also access mind maps using the quick actions menu or from the More section of the recents stack in the toolbar.
Note: It’s not possible to turn a shape with text into a mind map, but it can be dragged and connected to an existing mind map ↓
Add to mind map
You can add to mind maps by expanding from existing nodes and by dragging objects on your board to a node.
Expand from node
- Select an existing node.
- Click or in the direction you want to build.
- Click to edit the child’s text field.
You can also use FigJam AI to generate ideas and expand on an existing node.
- Click from the toolbar.
- Click Generate ideas.
Add existing object
- Select an existing object, such as stickies, shapes, and text.
- Drag and hover the object over the node you want to connect it to.
- When the icon appears, release the object to connect it to the node.
- Use
⌘CommandReturnto quick create a new child node. - Press
⌘Command⇧ShiftReturnto add a sibling node.
Learn more about speeding up your process with quick create →
Customize mind map
Use the selection’s toolbar to edit:
