Who can use this feature
Starter, Professional, Education, Organization, and Enterprise plans
While in beta, Figma Buzz is available on all seat types.
Figma Buzz templates help you quickly create assets—such as social media content, ads, emails, one-pagers, and more—from a pre-made design.
There are two type of templates:
- From Figma: A collection of templates curated by the Figma team. Use Figma-made templates if you have an individual use-case you’d like to explore.
- From your team: Templates made by your team or organization. Use templates made by members of your team to ensure you stay consistent and on brand.
Note: On the Organization and Enterprise plans, admins can disable the “From Figma” community templates from displaying in the template picker.
Some templates include multiple layout options that you can browse and customize directly in Figma Buzz. These flexible templates let you choose different layouts, configurations, or themes while keeping your content aligned with your brand.
Browse templates
When you create a new Figma Buzz file, you’ll see the template picker.
From the template picker, you can:
- Browse templates created by Figma or your organization
- Use the search bar to find templates by keyword
- Filter templates by category
- Select a New blank asset to design something from scratch
- Select the New template option to create a new template file
If a template is part of a template set, each layout variation appears individually in the picker.
You can:
- Click a single layout to add it to your file, or
- Select Add all templates to insert every layout from that set.
You can also browse templates from your organization or team's Resources section in the file browser.
Add additional templates to your file
You can add templates at any time, even after you’ve started your file.
- In the left sidebar, click Templates.
- Use the From Figma or Your team tabs to switch between public and internal templates.
- Select a template to add it to your file.
When you add a new template:
- If an asset is selected, the new template appears directly after it.
- If no asset is selected, the new template appears at the end of your file.
You can include multiple templates in one file.
Edit or customize templates
Once you’ve added a template to your file, you can personalize it.
Some templates include multiple layout options, configurable settings, or themes designed by your team. The options available to you will vary depending on how the template was built.
Edit content
To update text or image fields in a template, use Bulk edit.
- Click the Bulk edit icon in the left sidebar.
- Click the row for the asset you want to edit. A preview appears on the right.
- Double-click a cell to edit it:
- Text cells: Type directly in the cell. The preview updates as you type.
- Media cells: Hover over the cell to reveal the upload button, or use the inline toolbar to crop, adjust, or replace the image.
- Component properties/Variable modes: For assets built with components or variables from your design system, a dropdown appears with the available values or modes for that property. For boolean properties (like show/hide), click to toggle the value on or off.
Change layout
If your template includes multiple layout configurations, you can switch between them at any time.
- Select the asset on the canvas.
- Select the Edit content panel from the left sidebar.
- Click Change layout.
- In the Change layout panel:
- Use the Browse tab to scroll through available layout options.
- Use the Customize tab to adjust additional settings, like replacing images or logos, or toggling on/off visibility of other elements
The Change layout option only appears for templates that include multiple layout variations. If you don’t see it, your selected template may not support additional layouts.
Tip: You can also find layout options by selecting an asset and clicking Change layout from the editing toolbar.
Apply variable modes
Some templates support multiple themes—for example, different color palettes, sub-brands, or localized versions. These are powered by templates created with variable modes in Figma Design.
When a template includes variable modes, you can switch between them directly in Figma Buzz.
To change the variable mode of a template:
- From the inline toolbar, select Apply variable modes.
- Select the variable modes you’d like to apply from the dropdown menus.
The Apply variable modes option only appears for templates that were created using variables. If you don’t see it, your selected template may not support variable modes.
Why some fields may not be editable
On templates, some layers may be locked or restricted by the template creator. These editing guidelines help maintain consistency with brand standards and design style. Edit restrictions ensure everyone who uses the template adheres to approved fonts, layouts, and components—so your team’s assets stay on brand.
When guidelines are active, you can still:
- Update approved text and image fields in Bulk edit
- Switch between any available layouts using Change layout
- Switch between any available themes using Change theme
- Switch between available variable modes using Apply variable modes
Templates with editing guidelines applied are outlined in pink.
If you’d still like to make additional edits to a restricted template:
- Select the asset.
- From the inline toolbar, click Remove guidelines.
Note: It’s not possible to remove template guidelines from assets in bulk.
Related resources
- Edit assets in Figma Buzz: Learn how to edit assets directly within a Figma Buzz file.
- Bulk create assets in Figma Buzz: Generate multiple assets at once
- Create and publish Figma Buzz templates: Follow the full workflow for preparing and managing templates in Figma Buzz. Publishing templates is available on the Professional, Education, Organization, and Enterprise plans. Professional teams can create five team templates.
