Figma Buzz was released in open beta at Config 2025. It is currently available on all plans and seat types. Learn more about what’s included in the beta.
Who can use this feature
While in beta, Figma Buzz is available on all seats and plans.
Publishing templates is available on all paid plans. Professional teams can create five team templates.
Start from a template or from scratch to create exactly what you need. Edit, riff, and refine in a simplified editor.
If an asset on your canvas has a blue outline, it doesn't have template guidelines and can be edited freely. If an asset has a pink outline, it will have template guidelines built into it by the template creator. Template guidelines added by template creators can be removed.
Edit content in an asset
Once you’ve added an asset to your canvas and removed any guidelines, you can edit freely using the tools in the left navigation bar and inline toolbar.
Size
Select an asset and open the dropdown menu in the toolbar to choose a custom or preset size.
Learn more about resizing assets.
Fill
Click the color swatch in the toolbar to edit an asset’s background fill.
- Select a Color being used in the file or click to open the color picker.
- Add a Gradient to the asset. Hover over the gradient preview and click Adjust to customize the color and spread.
- Select Image & video to upload an image or video file from your device , or make an image using Figma AI.
Border
Add a solid or dashed Border to an asset.
Apply variable modes
If you’ve pasted a design from Figma Design that includes variables, select Apply variable modes from the inline toolbar to switch between available modes.
Add content to your asset
Text
Click or press T to open the text tool in Figma Buzz. You can choose from text formats like a title, headlines, and body text, or you can select a font combination to work from.
Once you’ve added text to the asset, you can select the text layer and edit:
- Fill
- Border
- Font
- Font style
- Size
- Formatting like bold, italics, and strikethrough
- Text alignment
- Effects like opacity, shadow, and blur
Click to shorten, rewrite, and translate text using Figma AI tools.
You can also apply library styles to your text.
Images
Upload an image, make one with AI, or insert free stock photos from Unsplash directly.
Once the image is on the canvas, you can:
- Add a border
- Crop, scale, rotate, flip, and reposition the image
- Adjust the image’s corner radius
- Effects like opacity, shadow, blur, and overlay
Learn more about adding and editing images in Figma Buzz.
Videos
Add .mp4 or .mov videos to your asset to build engaging assets with motion and audio.
Learn more about using videos in Figma Buzz.
Inserts
Use Inserts to add shapes or objects from your team libraries to an asset.
Learn more about using libraries in Figma Buzz.
Select multiple objects
You can select all matching text, images, or across assets on your canvas to make edits to them in bulk. In order for Figma Buzz to identify matching objects, they must contain the same content, like a string of text or image.
To do so:
- Select an object in an asset, like a text field or image.
- From the selection’s menu, click > Select matching objects.
Note: It’s not possible to select matching objects between assets with template guidelines and assets without guidelines.
Use Figma Design tools
Toggle in the toolbar to use Figma Design tools in your Figma Buzz file.
