Figma Buzz was released in open beta at Config 2025. It is currently available on all plans and seat types. Learn more about what’s included in the beta.
Who can use this feature
While in beta:
Figma Buzz is free for everyone.
Publishing templates is available on all paid plans. Professional teams can create five team templates.
Once Figma Buzz is out of beta, it will be included on the Full, Dev, and Content seats, in addition to our free Starter plan. We’ll notify you before that happens.
Start from a template or from scratch to create exactly what you need. Edit, riff, and refine in a simplified editor.
If an asset on your canvas has a blue outline, it doesn't have template guidelines and can be edited freely. If an asset has a pink outline, it will have template guidelines built into it by the template creator. Template guidelines added by template creators can be removed.
Edit content in an asset
Once you’ve added an asset to your canvas and removed any guidelines, you can edit freely using the tools in the left navigation bar.
Asset properties
Size
Select an asset and open the dropdown menu in the toolbar to choose a custom or preset size.
Fill
Click the color swatch in the toolbar to edit an asset’s background fill.
- Select a Color being used in the file or click to open the color picker.
- Add a Gradient to the asset. Hover over the gradient preview and click Adjust to customize the color and spread.
- Select Image & video to upload an image or video file from your device , or make an image using Figma AI.
Border
Add a solid or dashed Border to an asset.
Edit asset content
Text
Click or press T
to open the text tool in Figma Buzz. You can choose from text formats like a title, headlines, and body text, or you can select a font combination to work from.
Once you’ve added text to the asset, you can select the text layer and edit:
- Fill
- Border
- Font
- Font style
- Size
- Formatting like bold, italics, and strikethrough
- Text alignment
- Effects like opacity, shadow, and blur
Click to shorten, rewrite, and translate text using Figma AI tools.
You can also apply library styles to your text.
Images
Add an image to an asset from your computer or make one with Figma AI. Once the image is on the canvas, you can:
- Add a border
- Crop, scale, rotate, flip, and reposition the image
- Adjust the image’s corner radius
- Effects like opacity, shadow, blur, and overlay
Click to make a new image, remove background, or boost resolution with Figma AI tools.
Videos
Add .mp4 or .mov videos to your asset to build engaging assets with motion and audio.
Learn more about using videos in Figma Buzz.
Shapes
Add shapes to an asset that can contain a fill like a color, image, or gradient.
Inserts
Use Inserts to add objects from your team libraries to an asset.
Learn more about using libraries in Figma Buzz.
Select multiple objects
You can select all matching text, images, or across assets on your canvas to make edits to them in bulk. In order for Figma Buzz to identify matching objects, they must contain the same content, like a string of text or image.
To do so:
- Select an object in an asset, like a text field or image.
- From the selection’s menu, click > Select matching objects.
Note: It’s not possible to select matching objects between assets with template guidelines and assets without guidelines.
Use Figma Design tools
Toggle in the toolbar to use Figma Design tools in your Figma Buzz file.
