Who can use this feature
Available on any plan.
Anyone with can edit access on a file or folder can make changes to permissions on that file or folder.
In this article, learn how to remove or adjust people's access to individual files or folders.
To remove someone from a team or organization, see:
Folders
To change someone’s permissions or remove their access to a folder:
- Open the file browser by logging in to your account at figma.com.
- If you’re in a specific Figma file, click the Figma menu > Back to files.
- Open the folder page.
- On the Starter or Professional plan, select All folders from the left sidebar. Then, select a folder.
- On the Organization or Enterprise plan, select All teams from the left sidebar. Select a team, then select a folder.
- On the Enterprise plan with workspaces enabled, select All workspaces from the left sidebar. Then, select a team from the Your teams tab. Select a folder in that team.
- Click Share.
- Select the dropdown next a user’s name to adjust their access level or remove them from the folder.
Note: If someone has access to the folder through the team or parent folder that the folder sits in, removing them from a folder only removes their explicit access. They may still access the folder via inherited permissions.
Files
You can manage access from the file’s share modal.
- Open a file.
- Click the Share button in the toolbar.
- Click the dropdown next to a user’s name to adjust or remove their file access.
Note: If someone has access to the file through the team or folder the file sits in, removing them from a file only removes their explicit access. They may still access the file via inherited permissions.
What happens when you remove access
When you remove someone’s access to a file or folder:
- They no longer appear in the Share list.
- They can’t open or edit the file or folder unless they still have inherited access through an organization, team, or folder.
- If they left comments before removal, they may continue to receive email notifications on those existing threads.
