Remove people from an organization
Before you start
Who can use this feature
Supported on the Organization and Enterprise plans.
Organization admins and workspace admins can remove members and guests from the organization.
You can remove member and guests to revoke their access. This prevents people from accessing any teams, files, projects, or libraries in the organization.
Organization admins can remove any member or guest. Workspace admins can only remove people from the organization in workspaces they manage.
What to expect
Figma uses organization domains to determine who can join an organization. Members are accounts with email addresses that match an organization domain. Guests are accounts with external email addresses.
Existing teams, files and projects
When you remove a member, Figma keeps their contributions to organization teams, projects, and shared files.
While not required, we recommend you transfer ownership of the member's teams and projects before you remove them.
- Change the owner of a team
If you don't transfer ownership of a team before removing the team owner from your organization, the team won't have an owner. Organization admins can claim ownership of the team from the Teams tab in Admin settings. Team admins can continue to manage a team regardless of whether there is an owner assigned. - Transfer ownership of projects
If you don't transfer ownership of projects before removing the owner, they won't have a new owner until one is assigned.
Note: When a member is removed, their files will not be given a new owner. Any person with can edit
access to the files can continue to make changes or move them.
Drafts
When you remove a member from the organization, their drafts stay within the organization. Organization admins can view and manage drafts of deleted members from the Shared projects folder
Guests can still access their Figma account outside the organization. This includes any other teams or organizations of which they’re a member.
External teams
What happens to a member’s teams and drafts in their External teams depends on the organization's domain capture and SAML SSO settings.
- Domain capture on: Members will no longer have access to the Figma account under their company email. They will lose access to their drafts and any teams, files, and projects in their External teams.
- Domain capture off: Figma detaches their email address from the organization. This allows them to keep a Figma account registered under their company email. They won’t be able to access the organization, but may be able to access drafts, teams, and projects in their external teams.
- SAML SSO on: If you remove members from your identity provider, they won’t be able to log in to Figma using their company email. They won’t be able to access anything in their organization or external teams.
Remove in Figma
Both organization and workspace admins (Enterprise plan only) can remove members and guests.
Organization admin
Organization admins can remove members and guests from the Admin settings > Members.
- Open the organization in Figma.
- From the sidebar, go to Admin settings > Members.
- Use the search field to find the member or guest.
- Click and select Remove.
- Check the box next to I understand that this action isn't reversible and click Remove member.
Workspace admin Enterprise plan
Workspace admins can remove members or guests from Admin settings > Workspace > Members.
- Select Admin settings in the left sidebar.
- Select Members in the menu bar.
- If you manage multiple workspaces, select the workspac at the top of the member list.
Remove from SAML SSO or Google SSO
If your organization members are configured via SAML SSO, you will also need to remove the user from your identity provider.
This isn't something that we can help you with directly, but we've rounded up some documentation from our supported providers below.
- Azure: Add or Delete Users in Azure Active Directory (third-party documentation)
- OneLogin: Suspending or Deleting Users in OneLogin (third-party documentation)
- Okta: Deactivate and delete users accounts (third-party documentation)
- GSuite: Delete a user from your organization (third-party documentation)
Note: If you remove or de-provision a user via your identity provider, this may prevent them from accessing their external teams.
