Before you start
Who can use this feature
Available on the Organization and Enterprise plans
Any member of an organization can publish a private plugin to the organization
Only organization admins can publish public plugins to an organization profile. Publish plugins to the Community →
Organizations often have internal tools and systems, with private information or data, that can't be shared outside the organization.
Private plugins allows members of the organization to use organization-specific plugins, without having to share them with the rest of the Community.
- Any member of an organization can make and share a private plugin
 - Only team admins can publish plugins to the team's Community profile
 - Only organization admins can share plugins to the organization's Community profile
Publish private plugins
When publishing a plugin, you can use the Publish to setting to choose whether to publish the plugin to the organization or the Community. Private plugins don't need to go through the review process before they are available to use.
To create a private plugin for an organization, follow the steps to publish plugins to the Figma Community. On Add the final details page, set Publish to to your organization.
Only the plugin's original publisher can change the plugin's access. They can update this setting by publishing an update to the plugin.
Update the Publish to setting to change who can access the plugin. If you're changing a plugin from private to public, it will need to go through Figma's plugin and widget review process.
If the original publisher has left the organization and you need to transfer ownership of a private plugin, contact the Figma Support team.
View private plugins
To find and install plugins that are private to your organization:
- From the file browser, click All teams or All workspaces.
 - Select the Plugins header at the top of the page.
 - Browse through any plugins that are private to your organization.
 - Click the ↓ Save button to add the plugin to your account.
