Who can use this feature
Starter, Professional, Education, Organization, and Enterprise plans
Spec files, Figma Design, and FigJam
Specs is in open beta.
Figma Specs is a collaborative document editor that can be used on the Figma Design canvas and FigJam board alongside your designs and diagrams, allowing you to work with written intent, visual references, and technical details all in one place.
Use Figma Specs for things like:
- Placing usage documentation on the canvas next to library components so your team and agents have the context they need
- Riffing on multiple Specs on the canvas to align on a direction with your team
- Summarizing feedback from FigJam stickies during a team critique into a Spec
- Asking the Figma agent to create a technical specification doc from designs, or turning a tech spec into code layer
- Drafting a Spec by bringing in outside context via MCP, like your codebase or relevant data analytics
Create a Spec file
To create a new Spec file, navigate to the file browser and click Spec at the top.
You can also type figma.com/spec/new in your browser to create a new Spec file.
Insert a Spec into a file
A Spec can be created in Figma Design files and FigJam boards.
- From a Figma Design file or FigJam board, click Spec from the toolbar, or press D on your keyboard.
- (FigJam only) Select objects on your board and click Summarize AI to create a Spec based on the selected contents
- Prompt the agent to create a Spec—such as a brief based on frames and designs, a design critique agenda based on selected frames, or on-canvas design systems documentation.
Create content in a Spec
Note: Writing or editing Spec content requires edit access to the file. Manual writing and editing do not use the agent or consume AI credits.
Use a forward slash / to bring up a list of blocks you can add to your Spec. Some blocks can also be created using Markdown shorthand.
| Block type | Markdown shorthand |
| Heading 1 | # |
| Heading 2 | ## |
| Heading 3 | ### |
| Image | No markdown shorthand |
| Figma file embed | No markdown shorthand |
| Bullet list | * or - |
| Numbered list | 1. |
| To-do | [] |
| Quote | > |
| Code block | ``` |
| Divider | No markdown shorthand |
If you change your mind about a block and want to turn it into something different, click the handle > Turn into, then select the block type you want.
Tip: While you're working on a Spec within a Figma Design file or FigJam board, you can:
- Drag contents between the Spec and the canvas or board.
- Click View as scrollable page in the top-right corner of the Spec
- Click Open full-screen editor in the top-right corner to view the Spec in fullscreen
Collaborate
Collaborate with your team in a Spec by sharing, leaving comments, or spotlighting yourself during a presentation
Use Specs with other tools
Coding agents connected to the Figma MCP server can work with Specs using the figma-spec skill. Your agent can read, create, and update standalone Spec files and Specs embedded in Figma Design files and FigJam boards. Its edits are targeted, and comments stay attached to the right text. Learn more about Figma skills for MCP.
You can also use other tools to:
- Bring in context to draft a spec: Pull in context via MCP, like drafting a technical spec with the GitHub connector, or pulling relevant data from HEX into your PRD
- Push context back: Push context to external source, like updating Linear issues or your GitHub repo, based on a spec
- Use the agent with Spec: Turn on-canvas exploration into something your coding agent can easily ready/write to. Turn a PRD into designs and code, or turn designs and code into a technical spec.
Frequently asked questions
When will I get access to Figma Specs?
Specs is in open beta and available on Starter, Professional, Education, Organization, and Enterprise plans. Once the feature is available in your account, you’ll see the ability to create a Spec file from the file browser and from the toolbar Figma Design and FigJam files. If you don’t see Specs in your account yet, try refreshing the tab you're in or restarting the Figma desktop app.
Does using Specs consume AI credits?
Yes, using the agent with Specs consumes Figma AI credits.
Credit consumption varies based on a variety of factors, including task complexity and context the agent consumes. You can hover over the receipt after each prompt in the agent to see how many credits were consumed by each prompt.
Learn more about AI credit consumption.
Note: Once the agent in FigJam begins consuming AI credits, credit consumption will apply to using the agent with Specs in FigJam as well.
Can I write and edit specs without using the agent?
Yes, writing and editing content directly in the Spec does not use the agent and will not cost AI credits.
