Plugin parameters
Developers can create plugins with parameters which allow plugins to accept user input from the quick actions menu. Adding parameters to your plugin means you don't need to build a custom UI. It also provides a streamlined experience for users of the plugin, who can run a plugin directly from the quick actions menu. Learn more about quick actions →
Example:
This plugin creates a shape on the canvas. It has no UI and can only be run via the quick actions menu (Mac) ⌘+/ (Windows) Ctrl+/. A user can select a shape type for the Shape
parameter, then input number values for the Width
and Height
parameters to define the shape's dimensions.
Check out these plugins powered by your keyboard →
Make plugins with parameters
Anyone can develop a plugin with parameters. If you're new to developing plugins, learn how to make plugins for the Figma Community.
Figma's developer platform provides a detailed setup guide for the plugin API. If you're ready to start building, read the developer documentation →
Use plugins with parameters
Anyone can install and run a plugin and use its parameters.
Users on the Organization plan can publish plugins with parameters to their Organization privately.
Publish plugins with parameters
New plugins that are parameter-only
Plugins that only use parameters (those without a user interface outside of quick actions) can be published to the community and will be approved according to our plugin review guidelines.
Learn more about publishing plugins to the Figma Community →
