Figma has a number of features under development that are available to users in beta. In this article, find out which beta features are available, what they are, and how to access each one.
Note: Beta features can change during the beta period. You may experience bugs or performance issues during this time.
Agent in Figma Design closed beta
Before you start
Who can use this feature
Available on Professional, Organization, and Enterprise plans
Users with Full seats can use the agent in all Figma Design files
Users with Dev or Collab seats can try the agent in Figma Design files in Drafts
Requires edit access
The agent in Figma Design helps you explore, edit, and refine designs through natural conversation.
Use the agent to:
- Generate and remix designs using your design system components, styles, and variables
- Automate bulk edits—update copy, swap content, apply variables, and restructure layouts across multiple frames at once
- Get design feedback, including accessibility reviews and critiques from different user personas
- Ask how-to questions about Figma—the agent draws from the Help Center for accurate answers
- Run multiple prompts in parallel without waiting for each to finish
Starting May 20, 2026, the agent is rolling out gradually to users on paid plans. Learn how we're rolling out the agent and how to join the waitlist.
Figma Make in your local codebase closed beta
Before you start
Requires the Figma Beta desktop app for Mac
Requires a codebase hosted in a Git repository
Figma Make in your local codebase lets you connect a Git repository and edit the running app directly inside Make. Your app opens with real data, and you can change the UI by adjusting properties in a panel, annotating elements, or describing changes in chat. The agent updates the code, and when you're ready, you can create a branch and open a pull request without leaving Figma.
Use Make in your local codebase to:
- Open a local repository or clone one from GitHub and see your live app with real data
- Adjust layouts, colors, fonts, and spacing on selected elements with the editing panel
- Annotate specific elements to describe changes in context, and stack annotations to queue several changes at once
- Chat with the agent to describe code changes in plain language
- Create branches, make local commits, and open pull requests for your engineering team to review
Make in your local codebase is rolling out gradually to accepted participants. Join the waitlist to apply for access.
Write to canvas open beta
Before you start
Write to canvas is in open beta.
Write to canvas is available to Full and Dev seats on paid plans.
Dev seats only have read-only access outside of drafts.
Write to canvas lets AI agents create and modify content directly in
your Figma
files using the use_figma tool in Figma’s MCP server.
With use_figma, agents can write real, editable content
to the canvas
instead of a rough approximation. Depending on the workflow and skill
being used,
this can include creating and updating content in
Figma Design files or working with
FigJam boards.
You can use Write to canvas to:
- create and update content in Figma Design files
- work with FigJam boards through supported FigJam skills
- build with your team’s existing components, variables, layout structure, or board content
- turn prompts into real, editable canvas content
Learn more about write to canvas.
Write to canvas FAQ
Write to canvas can support both Figma Design and FigJam workflows, depending on the tool and skill combination being used.
Slots open beta
Slots, a type of component property, are flexible areas added to components that let you freely add and arrange content directly inside an instance without having to detach it, all while maintaining adherence to your team's design system.
- Use slots in components with repeating items—such as task lists—or freeform layouts—like cards and modals.
- Simplify design systems and pattern libraries by decreasing the number of variants or hidden layers needed to express the number of ways an asset can look
- Allow for experimentation while adhering to accurate component usage
- Maintain design system health by reducing occurrences of detached components so instances will continue receiving updates from the main component
Slots FAQ
Slots is now rolled out to all Full seat users. If you're unable to access the feature, refresh the design file and check if you have edit access to it.
Figma Buzz open beta
Before you start
Figma Buzz is in open beta.
While in beta, Figma Buzz is available on all seats and plans.
Figma Buzz enables brand designers to build workflows for marketers to create campaigns confidently and move at the pace of their ideas—all within Figma. Use Figma Buzz to make assets such as social media posts, digital ads, event materials, and more.
- Publish templates: Copy and paste from Figma Design to Figma Buzz, make necessary tweaks in design mode, and publish in buzz for your peers to easily access and use.
- Controlled editing: Teams can edit select sections within published templates, ensuring they are always staying on brand.
- Freeform editing: Select a template, start from scratch, or use a custom size to create exactly what you need. Riff and refine with design tools in a simplified editor.
- Creation at scale: Quickly create and edit thousands of assets at once. See them all in one view, regardless of size.
Figma Buzz FAQ
Figma Buzz is available on Education plan accounts.
Figma Buzz is not available on Figma for Government.
Yes, AI features are available in Figma Buzz.
See a list of AI features available in Figma Buzz.
As an admin, you can choose to disable access to AI features for your team or organization.
Figma Sites open beta
Before you start
Figma Sites is in open beta.
Figma Sites is available on all plans. Publishing a site to a live domain requires a paid plan.
Requires a Full seat to edit and publish sites. Users with Dev, Collab, or View seats can view site files.
Figma Sites is an all-in-one tool for designing, prototyping, and publishing websites. In Figma Sites, you can:
- Copy from Figma: Copy and paste your Figma designs into Figma Sites for easy migration.
- Templates: Get started with pre-designed website templates.
- Assets & blocks: Pull in your design system and premade web elements.
- Breakpoints: Layouts, text, and components can adapt for different screen sizes.
- Interactions: Apply interactions like marquee, scroll parallax, and much more with a few clicks.
- Preview & publish: See live HTML preview in canvas and publish designs straight to the web.
Figma Sites FAQ
In Figma, a user’s seat type determines which Figma products and functionalities they can access.
- In Figma Sites, a Full seat is required to edit and publish site files.
- Users with Dev, Collab, or View seats can view site files.
During the beta, we're gradually enabling publishing capabilities.
Here's what you can expect:
- Publishing is being rolled out gradually to users. You may be able to create and edit sites before you can publish them.
- If you attempt to publish and see a disabled state or a tooltip message, your account hasn't yet been enabled.
- We'll notify you directly in-product once publishing is activated for your account.
If you currently can't publish your site, it may not have rolled out to your account yet. Or, if you’re on the Organization or Enterprise plan, your admin may have turned off publishing capabilities for your organization. Learn more about managing site publishing for an organization.
By default, anyone with a Full seat can publish a site to the web using Figma Sites. On the Organization and Enterprise plans, organization admins have the ability to disable site publishing to align with their company’s information security practices.
Learn more about managing web publishing for an organization.
There are no limits on published websites.
Yes, Figma Sites supports custom site domains. Organization and Enterprise plans can set up unlimited custom domains, and Professional plans can set up 10 custom domains free of charge through 2025.
Figma Sites is not currently available for Figma for Government accounts.
Figma Sites is available for Figma for Education accounts.
While in beta, Figma Sites is available to all paid plans. Go to figma.com/pricing-faq to learn more.
Figma is not responsible for content that is published from Figma Sites. Published sites are accessible to anyone on the public web, and you are responsible for complying with any regulations or laws that apply to your content or any data you collect from visitors to your published sites. If you're unsure about what those obligations are or how to comply with them, please consult a lawyer.
Figma reserves the right to remove any published content that is reported and determined to violate Figma’s Acceptable Use Policy.
Desktop app open beta
Figma has a beta version of the desktop app available.
By using the beta version of the app, you're helping Figma test bug fixes and performance improvements, before we release them to the general public. The beta version does not give you access to features Figma hasn't released yet.
You can install and use the Figma desktop app and the beta version at the same time. Both versions of the desktop app will offer the same core features and functionality.
Learn how to download the beta version of the desktop app.
